Does anyone print onto the 3.5oz Durham mugs that Listawood supply using a wrap and cooking in an oven? I have seen wraps for Expresso mugs this size but not Durham. Listawood do not supply a wrap for this mug advising to use a press instead.
Following on from help given by this forum I am keen to use an oven as results seem to be much better and can get closer to the handle with the print.
Mug diameter is 60mm and height 70mm Distance from one side of handle to the other 180mm.
Thanks in advance
John
