User Tag List
Similar Threads
  1. HELP! how do I cancel a cut job Graphtec CE5000-60
    By sarahjayne in forum Vinyl Cutters
    Last Post: 29-11-2023, 09:37 AM
  2. General Maintenance Graphtec CE5000-60?
    By Stitch Up in forum Vinyl Cutters
    Last Post: 17-09-2016, 09:32 AM
  3. Graphtec ce5000-60 good cutter.?
    By Ravisteam in forum General Dye-Sub Chit Chat
    Last Post: 03-03-2016, 12:43 PM
  4. Graphtec CE5000-60 Problem
    By gstk in forum Vinyl Cutters
    Last Post: 14-02-2011, 07:05 PM
  5. Graphtec CE5000-60 problem
    By gstk in forum Vinyl & Flock
    Last Post: 29-12-2010, 04:54 PM
Results 1 to 5 of 5
  1. #1
    Senior Member Stitch Up's Avatar
    Join Date
    Oct 2009
    Location
    Bridgend, South Wales
    Posts
    1,422
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Graphtec CE5000 - ROLL1 or ROLL2 ?
    We've had our Graphetc since the beginning of time and it's been a workhorse and still going strong.
    When I went to use it today, following a power cut, the display showed SHEET. I'm quite sure we've always used ROLL2 and never tried ROLL1.
    What are the pro's & con's of ROLL1 & ROLL2? Which do you choose?
    Cheers
    JOhn
  2. #2
    Senior Member logobear's Avatar
    Join Date
    Feb 2010
    Location
    Newcastle upon tyne. UK
    Posts
    1,669
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    if you use SHEET, the machine feeds the media back and forward to discover its size.
    We put tape over the sensor located at the back about 6 inches from the right hand side of the cut path.
    Roll 1 and 2 are just for different media configurations.
    WE cover the sensor and have it on ROLL ?
    The cutter does occasionally switch to sheet - inwhich case it feeds and feeds and feeds.
    Just change it back
    thats what we do
  3. #3
    Senior Member
    Join Date
    Nov 2015
    Location
    dorchester
    Posts
    1,199
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Never had a Ce 5000 but on the Ce6000 Roll 1 winds the media back to the front edge and Roll 2 starts cutting from the possition as loaded. I would think the 5000 would be the same(?)
  4. #4
    Join Date
    Oct 2009
    Location
    Posts
    1,422
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks guys, I'm sure we've always used ROLL2 in the past but switched to ROLL1 last night and noticed it parked the leading edge further back than I would normally have set it using ROLL2
    When using ROLL1 do you still have to set origine?
    Cheers
    John
  5. #5
    Senior Member
    Join Date
    Nov 2015
    Location
    dorchester
    Posts
    1,199
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Not on the 6000. Roll 1 sets the edge of the media about 1.5 cm past the blade. You can go back a little with the origin if you want.
    Roll 2 sets the media wherever it is when you close the lever.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
