User Tag List
Similar Threads
  1. Serial Lead for PC to Tajima Neo TEJT C1501
    By Stitch Up in forum Embroidery
    Last Post: 31-07-2016, 09:03 PM
  2. Tajima Neo TEJT C150 - Error 322 Check! X Motor
    Last Post: 21-06-2016, 07:32 PM
  3. Ricoh SG Registration Misaligned
    By Jerry in forum Printing Problems/Issues
    Last Post: 22-05-2016, 12:18 PM
  4. Replies: 14
    Last Post: 01-10-2014, 01:47 PM
  5. Heat press misaligned
    By crystaluk in forum Heat Presses
    Last Post: 04-10-2012, 04:51 PM
Results 1 to 5 of 5
  1. #1
    Senior Member Stitch Up's Avatar
    Join Date
    Oct 2009
    Location
    Bridgend, South Wales
    Posts
    1,422
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Needle Bar Misaligned? Tajima Neo TEJT C1501
    Hi guys
    If I manual pull down needle bar 12 on our Tajima Neo TEJT C1501 machine, the needle tip is out of alignment with the hole in the bobbin plate!
    How can this be remedied?
    Cheers
    John
  2. #2
    Senior Member logobear's Avatar
    Join Date
    Feb 2010
    Location
    Newcastle upon tyne. UK
    Posts
    1,669
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    just bend the metal back .... you probably hit a hoop at some stage ?
  3. #3
    Join Date
    Oct 2009
    Location
    Posts
    1,422
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the reply - I always shy away from bending things :)
    I'll give it a try later.
  4. #4
    Join Date
    Feb 2010
    Location
    Posts
    1,669
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    if it goes wrong, just swap it for one at the far end that you rarely use !
  5. #5
    Join Date
    Oct 2009
    Location
    Posts
    1,422
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Done that :)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
