User Tag List
Similar Threads
  1. Freesub ST-210 mug press What other products can go in it?
    By Mach-One in forum Mug Presses & Ovens
    Last Post: 23-09-2018, 01:07 PM
  2. Freesub ST-210 Heat up test
    By Mach-One in forum Reviews Section
    Last Post: 23-09-2018, 12:58 PM
  3. Freesub double mug press help
    By jennywren in forum Mug Presses & Ovens
    Last Post: 05-11-2017, 12:08 PM
  4. Freesub St-210
    By paul 44 in forum Mug Presses & Ovens
    Last Post: 18-10-2017, 06:15 PM
  5. Freesub ST-4050a Reviews
    By PeteO in forum Heat Presses
    Last Post: 10-08-2016, 10:32 AM
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: FreeSub ST-210
  1. #11
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,385
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by John G View Post
    Not sure if it would beat an oven - but it's definitely faster than my old Coralgraph press, if you're doing 2 mugs at a time.
    So how long would 36 take?
    36 in an oven will take about 35-40 minutes plus an additional 15 minutes for the oven to warm up
    72 would take an hour and ten.
  2. #12
    Senior Member logobear's Avatar
    Join Date
    Feb 2010
    Location
    Newcastle upon tyne. UK
    Posts
    1,669
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    in an over you need 36 jackets, and probably 72 so you can prep while cooking .... thats a lot of £$£ on top.
    With an oven, you do all the work, then sit back for half an hour, then do some more.
    With a few presses, its more continuous, but easy to fit around doing other things .... init?
  3. #13
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,385
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by logobear View Post
    Yes and no :-)
    Not really trying to start a topic on mug v presses (unless you want me to :-)), I have both and both have their good and bad points.
    I am just interested in how long a box or two would take as I see good reviews about this press so was just curious.
  4. #14
    Member
    Join Date
    Jan 2018
    Location
    Worcester
    Posts
    79
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have one of these and it's great, though I do tend to put one mug in at a time as I only normally do one-offs as and when required. I had an order for 30 last week so decided to do 2 at a time but got similar issue to that of Gooner Gary. Hence i just stick to doing one at a time .
  5. #15
    Senior Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,369
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    You see the reason I started the thread was that I wasn't sure if I had a dodgy press, before I start buying more. Not only will it randomly countdown immediately, but when you switch off the right side of the press with the red button, the left hand side also stops its counter!
    I'm printing 36 mugs as I type on one side of the freesub and two adkins presses..It took 45 mins without any faffing with clamps. if I make a mistake, the new mug will be ready in 166 seconds.
    The Freesub will print a single mug in 4 and a half mins on average if you want to work out times.
  6. #16
    Senior Member
    Join Date
    Nov 2009
    Location
    Newcastle upon Tyne
    Posts
    2,937
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would say 36 mugs would take approx 75 - 80 mins, including taping the paper on the mug.
  7. #17
    Senior Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,369
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    why do you have the idle so high?
    At this temp, surely the mug will start to sub straight away ... then cool down, stop, and re start as temp is reached, - smudging?
    I thought the purpose of idle was to pre warm the mug to say 120c ... and then hit GO - heats up to cooking temp, then begins count ?
    what do i know?
    FREESUB ST-210 looks like a pretty bit of kit ... why do you need to press mug for longer?
    This doesn't work. It works for the first mug because the press is heating up from cold. But when you do the second mug, the press only cools down as far as 150 degrees. This resulted in under cooking of the second mug. Or else I have a wildly inconsistent press.
  8. #18
    Junior Member
    Join Date
    Jun 2018
    Location
    Durham
    Posts
    12
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have had the dual mug press since August - worked fine to begin with but recently the temperature has become erratic. Can jump to 200 degrees in a second (i have it set to 175) - resulting in overcooked mugs. Very frustrating. Has anyone else experienced this issue...?
  9. #19
    Member
    Join Date
    May 2016
    Location
    Peterborough
    Posts
    37
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    In my Genie i'll admit I ignore the press timer - I idle at 170, pop mug in, set manual 2m 30 timer on pc by which time the mug is usually subbed (only gets back up to temp about 10 secs before timer usually).
Posting Permissions
  • You may not post replies
  • You may not edit your posts
