User Tag List
Similar Threads
  1. how do i trace only outside edge in inkscape??
    By soulclaimed in forum Vinyl Cutters
    Last Post: 15-02-2013, 12:36 AM
  2. Inkscape and Ricoh printing
    By JBr in forum Software
    Last Post: 12-10-2012, 05:30 PM
  3. Signcut Pro vs Flexisign
    By busybusybee in forum Vinyl Cutters
    Last Post: 09-03-2012, 12:39 PM
  4. Gimp/Inkscape - Viable alternatives?
    By Justin in forum Software
    Last Post: 03-08-2011, 09:34 PM
  5. Signcut Pro
    By Kaz in forum Software
    Last Post: 08-03-2010, 10:07 PM
Results 1 to 6 of 6
  1. #1
    Junior Member
    Join Date
    Sep 2018
    Location
    Sandhurst
    Posts
    12
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Inkscape and Signcut HELP
    Hi all
    I am new to this and using Vinyl heatpress to personalise bags.
    I have a pixmax plotter cutter which I have been told is ONLY compatible with either Signcut Pro or Flexistarter.
    I am trying out Signcut pro but I am annoyed that I have to create the text vector graphic file in another programme and then import to Signcut Pro
    So I have a few basic questions and one a little more complicated, Please would be great if you can answer what you can
    1) Signcut or Flexistarter? Can you design and cut in Flexistarter?
    2) I am using Inkscape for now, but is Illustrator easier/better?
    3) To create my vector file for Sign cut I take the following steps
    a) Type name to be cut in Vinyl in Inkscape
    b) Path > Object to Path
    c) Save
    d) Open file in Signcut
    e) Cut
    The problem I have is that the font I am using is a joined up writing font, when this is cut out in the plotter cutter when one letter is joined to another it creates weeding lines around each individual letter, however, where it is joined up I want that to remain a fluid continuous flow.
    As I am doing lots of different names, does anyone know how I can change this? Is it in Inkscape or Sign cut?
    Thanks,
    Reena
  2. #2
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Unfortunately, it does look like you're stuck with having to use those softwares for cutting.
    As for joining your letters together, try selecting the whole text, convert to Path, then select the 'Union' boolean command from the Path menu.
    I rarely use Inkscape. SCAL5 works great with my particular cutter and has design features built in, as well as all the cutting features.
  3. #3
    Junior Member
    Join Date
    Feb 2014
    Location
    Milton Keynes
    Posts
    8
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Signcut has an illustrator plugin so you can do your designs in illustrator and then click on “send to signcut” and it automatically opens signcut with your design already open. All you have to do then is to double check your settings and click on cut out to start the job.
  4. #4
    Junior Member
    Join Date
    Sep 2018
    Location
    Sandhurst
    Posts
    12
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok, I have now moved from Inkscape to Illustrator, anyone know how I can overcome the problem I had before ("The problem I have is that the font I am using is a joined up writing font, when this is cut out in the plotter cutter when one letter is joined to another it creates weeding lines around each individual letter, however, where it is joined up I want that to remain a fluid continuous flow."). How do I ensure continuous flow in Illustrator?
    Member
    Join Date
    Jul 2017
    Location
    PONTYPRIDD
    Posts
    190
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Select the text, go to "Window - Pathfinder" and choose "Unite".
    This welds the text into a cuttable shape with no overlaps although it's good practice to keep a copy unwelded so that you have something to edit in future should you need to change the wording.
  6. #6
    Junior Member
    Join Date
    Sep 2018
    Location
    Sandhurst
    Posts
    12
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    @StellaD please accept my apologies, I so forgot to reply to say Thank you! This worked!!
    Quote Originally Posted by StellaD View Post
Posting Permissions
  • You may not post replies
  • You may not edit your posts
