User Tag List
Similar Threads
  1. halogen oven vs Sublimation vacuum oven
    By smiley_mug in forum Mug Presses & Ovens
    Last Post: 21-08-2023, 03:21 PM
  2. Replies: 16
    Last Post: 29-07-2017, 12:57 PM
  3. Upgrade to Win 10 ?
    By Disky in forum Software
    Last Post: 05-05-2016, 08:48 PM
  4. Which printer to upgrade to?
    By chez in forum Printers
    Last Post: 06-11-2012, 07:27 AM
  5. cubecart upgrade
    By Paul in forum Software
    Last Post: 08-03-2010, 03:19 PM
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
  1. #11
    Senior Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,369
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Which oven are you using Justin?
  2. #12
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,253
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    Blizzard....
    https://www.catering-appliance.com/b...SABEgLwiPD_BwE
    Tried to get us a discount with the seller but margin is too tight. Highly recommend them though ;_)
  3. #13
    Senior Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,369
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Aye, that's the one I've got bookmarked. I have this awkward cable enclosure running around my walls which reduces the depth of my worktop, preventing a 600mm oven on it...aaaahh nothing is ever straightforward. I'm assuming that you couldn't put a hot oven on an ordinary IKEA laminated table...it would probably melt?
    More here though...
    https://www.catering-appliance.com/c...stock-due-soon
  4. #14
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,385
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    f you're printing mugs regularly the oven is most definitely the way to go. I haven't switched my presses on in months now.
    Can I say "told you so" yet :-) :-) :-)
    we can do 24 mugs in 30 minutes and no annoying wraps to put on and take off. Both have valid uses in our opinion.
    I can do 72 mugs per hour. I never use my presses these days, even if I only have one mug to do. The mug presses are too unreliable in my opinion in that the blankets will deteriorate with age and way too much hassle to keep monitoring. I also really do not understand this annoying wraps bit either. it literally takes 2 seconds to do and if you get into a run then you do them while the others are printing. Mug wrap £4.00 and lasts about 500 mugs, blanket £30.00 and might last 500 mugs. I do use my press but only for TMT's CPM work these days.
    Gooner, take a look at how and where mine is situated. This bench is what is known as a nuns dining table (obviously from my past life), it is solid wood with a varnished surface. I placed a bit of table cloth liner on top then plonked the oven down, there are no marks/scratches/melted bits that relate to the oven being on. It does not get that hot on the outside. Further more, you can see the depth of the table is quite narrow and you could actually overhang if you wanted to. If you want to see a different angle to the oven or table let me know.
    Trust me guys, as I said to Jason and Justin, buy an oven and you will never look back. Both will confirm that it is one of their best investments... :-)
    My only gripe is that I need to either find or get some bespoke trays made. The ones that are supplied are really flimsy and after tens of thousands of mugs they really are at their end of life.
    Attached Images Attached Images
  5. #15
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,385
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    Also, Gooner I thought it was you who put me on to this particular oven. The key thing to look at is internal dimensions. I did a lot of working out on paper before going with this particular model as I wanted to be able to get sufficient amount of mugs in.
    With this model I am pretty sure that if I got some side bars made you may even be able to get 36 mugs printing in one go.
  6. #16
    Senior Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,369
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by socialgiraffe View Post
    You did indeed thanks, it was the depth issue which made me look for other possibilities. But your measurements look about 8cm shorter than the advertised dimensions. Look, sod the halogen oven experiment, I'm going to order this Blizzard instead and will have a hunt for other baking trays for you.
  7. #17
    Premium Member
    Join Date
    Jan 2016
    Location
    Manchester
    Posts
    239
    Downloads
    0
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    This thread is even make me think about testing the water with ovens....
  8. #18
    Senior Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,369
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    I've got my roll-and-wrap® silicone mug wrap technique perfected in less than two seconds...full steam ahead. :)
  9. #19
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,385
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    There's nothing like a 2 month old Adkins blanket almost causing a nasty fire yesterday to get your finger out and buy the Blizzard oven. What were you saying about unreliable presses social?!
    Justin will have the "wrap a mug in under 2 seconds" challenge at P&P. Going to start practicing as I really want to win the cash prize he is sponsoring :-)
    Glad you have decided to move over, there will be a little bit of fiddling, but no where near as much as with a press. The below is cut and pasted from an email I sent to Jason and Justin which will give you a start...
    You can see where I have my dial on the images posted. It might be worth Justin and Jason posting their settings so we can compare...
    Listawood 10oz @ 8 minutes
    Listawood 11oz @ 9 minutes
    The more mugs the longer the time, 24 mugs take 16-18 minutes for me (depending on how cold the mugs are before they go in). Don’t forget to let the oven warm up for about 15 minutes before starting your first mug.
    Make sure the bleed is a max of 2mm top and bottom. I personally have no bleed at the top and 1mm at the bottom. Too much bleed and you will get the ink dispersing over the exposed areas of the mug (i.e under the handle).
    Always make sure the mug paper is longer than the wrap. Mine is cut to 240mm wide although I should probably do it a few mm shorter.
    Below is a link to the thermoshrinkable. I have linked the mugs, but there are other sizes. Cheap as chips J
    https://shop.bestsublimation24.eu/pr...BGZ18-mug.html
    The seller I got my wraps from does not have any at the mo, however the below work out at £4.30 each so still pretty good
    https://www.ebay.co.uk/itm/11OZ-10pc...item3aafeb9cd0
    I clean the wraps about every thousand mug prints. To do this just put them all in the oven, turn the temp up to full what and “cook em” for about half an hour. Hold your breath when you take them out!
  10. #20
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,253
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    Haha, wrap a mug in under 2 seconds. You'll have to wrap a box of 36 to get any money out of me! ...and can you print them as well please, ta very much.
    Seriously though, many thanks to Simon for funding the food and drink throughout the show. I believe he's put money 'behind the bar' in the restaurant area so you just go up to the staff and say "I've just seen a flying pig dressed as a rainbow unicorn....and I hear Simon's put his hand in his pocket!!!" and they give you a free escort out of the NEC ;-)
    Back on track.....the ovens really are good. I expected to have to play around with settings for a while but after a couple of mugs it was fine. Switch on your single head press after a few weeks of using this and you'll see what a faff it is and the results speak for themselves.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
