Join our Premium Membership now and save with Xpres, Listawood, Ink Express and more! Just £10 per year.....Click the Membership link above.....
User Tag List
Similar Threads
  1. Testing Wilko's new 'sublimation' paper
    By Customprintwales in forum Reviews Section
    Last Post: 23-05-2018, 07:55 PM
  2. New FAQ Section in progress
    By Justin in forum Forum Information/Updates etc.
    Last Post: 15-04-2013, 08:05 PM
  3. Replies: 26
    Last Post: 24-11-2012, 06:12 AM
  4. Progress update!
    By SciArtImages in forum Mug Presses & Ovens
    Last Post: 01-08-2011, 11:04 AM
  5. Sublimation printer printing wrong colours
    By Photo-Lite in forum Printing Problems/Issues
    Last Post: 03-05-2011, 09:20 PM
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Administrator Mini KickUps Champion Justin's Avatar
    Join Date
    Sep 2009
    Location
    Shetland
    Posts
    8,883
    Downloads
    6
    Uploads
    1
    Mentioned
    5 Post(s)
    Tagged
    1 Thread(s)
    I'm just testing the ET2650 for myself. Initial results are excellent even compared to my 1500W (Although profile is a little off with that!) but the ET really is painfully slow. Switching to normal from high quality doesn't seem to speed it up much either!
  2. #12
    Member
    Join Date
    Feb 2013
    Location
    Derby
    Posts
    48
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The ET3700 is £190 Ex. VAT on ebuyer. Might be worth testing. I like the fact the new Ecotanks have the fill levels on the front rather than the side.
  3. #13
    Supplier InkExpress's Avatar
    Join Date
    Mar 2018
    Location
    Wolverhampton
    Posts
    252
    Downloads
    0
    Uploads
    0
    Mentioned
    5 Post(s)
    Tagged
    8 Thread(s)
    Quote Originally Posted by Justin View Post
    The print heads / area they print is small this is the main issue with the speed. For me, I am happy to wait for a quality print, but can definitely see a slow print speed getting annoying in a business environment.
    | 01902 307111 |
  4. #14
    Member
    Join Date
    May 2013
    Location
    London
    Posts
    417
    Downloads
    0
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I have seen L1800 look and quality slimier to 1500W ..They are about £480 but not in UK lol...My concern about Eco tank was if the tank develop a fault it would be really hard job to replace them right but ciss is a pretty easy swap ..
  5. #15
    Member
    Join Date
    May 2013
    Location
    London
    Posts
    417
    Downloads
    0
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    And my other concern about Eco Tank is how do you swap ink if you needed to (sub ink to dye ink etc..) ??..
  6. #16
    Premium Member
    Join Date
    Nov 2011
    Location
    Bishop Auckland, County Durham
    Posts
    3,739
    Downloads
    0
    Uploads
    0
    Mentioned
    2 Post(s)
    Tagged
    1 Thread(s)
    To swap ink, you would need to empty as much from the tanks as possible, and refill them with printer cleaning fluid, and then run like this until the printer prints just clear fluid - there may be a purge/initial fill mode option which would really help to do this, and once done drain off the cleaning fluid and fill with the new ink - a similar process we use with large format printers with a bulk feed system.
  7. #17
    Join Date
    Mar 2018
    Location
    Wolverhampton
    Posts
    252
    Downloads
    0
    Uploads
    0
    Mentioned
    5 Post(s)
    Tagged
    8 Thread(s)
    Quote Originally Posted by Ravisteam View Post
    The L1800 is a great printer, but the lack of UK warranty is always an issue. Especially for a reseller, as an end user I would certainly buy one and risk it. You are correct if the Eco tank developed a fault this would cause issues, however I am personally yet to come across one that has so in my experience they are reliable in that sense.
    Personally I don't advise swapping between dye sub and regular inks as it requires a large amount of head cleaning (usually) I often use my dye sub printers (using dye sub ink) to print normal documents such as invoices, letters, emails things like that.
    It works well, saves having to swap and change inks and also gives the printers some work if we aren't using them for dye sub printing for a few days.
    Alex
    | 01902 307111 |
  8. The Following User Says Thank You to InkExpress For This Useful Post:
    Ravisteam (27-02-2019)
  9. #18
    Junior Member
    Join Date
    Feb 2019
    Location
    London
    Posts
    2
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    @InkExpress
    Hi Alex I was wondering how you're getting along with the testing of the ET2700 / ET2710. I'm looking for a starter sublimation printer package and as these models are newer versions of the ET2600 it would make sense to buy one of these.
    I'd be more than happy to buy through your company if the testing turns out good and you have a ICC profile ready.
    Cheers
  10. #19
    Join Date
    Mar 2018
    Location
    Wolverhampton
    Posts
    252
    Downloads
    0
    Uploads
    0
    Mentioned
    5 Post(s)
    Tagged
    8 Thread(s)
    Quote Originally Posted by Beehousedesigns View Post
    @InkExpress
    Cheers
    Hi, we are about ready to launch the ET2710, the ICC is made and testing has been sucessfull it is producing comparable results to the other 4 colour printers we have sold in the past.
    The ET2600 is still current and at present is the bets value as its the lowest initial purchase price at just under £189.00 all in. I believe ET2710 will cost around £20.00 more per unit so would make the package come in at around £209.00 Inc. VAT and carriage.
    ET2600 are in stock ready to ship, ET2710 can be ordered in if you wanted one. I have not ordered in a batch yet as we still have stock of the ET2600.
    Alex
    | 01902 307111 |
  11. #20
    Join Date
    Sep 2009
    Location
    Shetland
    Posts
    8,883
    Downloads
    6
    Uploads
    1
    Mentioned
    5 Post(s)
    Tagged
    1 Thread(s)
    Alex, do you know the difference between the ET-2600 and the ET-2650? Quick Google and it looked like the only difference was the 2600 doesn't have the screen?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
