Evening all,
I recently switched from your typical A4 sub paper to pre cut mug size paper, one of the most sensible moves I've made thus far.
Now my question. Everywhere cut size is 240mm in width, meaning the paper touches the handles, I've narrowed my print size down to around 210mm wide to avoid faded edges, but can find some inconsistencies in the print and edges, something I suspect may be due to the paper being forced off the mug my too much paper against the handle when under pressure in the press.
Does anyone have any recommendations regarding mug cut paper size, do you pre trim like I am now doing, am I missing a trick.
Anyones time is appreciated.
