User Tag List
Similar Threads
  1. A4 Plastic sheets?
    By edwardsmedia in forum Sourcing New Items
    Last Post: 14-04-2023, 01:56 PM
  2. Unisub MDF Sheets Available?
    By UK Printed Mugs in forum General Dye-Sub Chit Chat
    Last Post: 04-03-2016, 11:52 AM
  3. Silicone Sheets
    By GoonerGary in forum Mug Presses & Ovens
    Last Post: 14-03-2014, 10:12 AM
  4. DJ Lycra sheets?
    By Dave271069 in forum General Dye-Sub Chit Chat
    Last Post: 05-08-2013, 11:06 AM
  5. carrier sheets
    By sarahjayne in forum Vinyl Cutters
    Last Post: 30-05-2012, 12:38 PM
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: FRP sheets...
  1. #11
    Senior Member mrs maggot's Avatar
    Join Date
    Dec 2009
    Location
    kettering, northants
    Posts
    3,365
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have you thought about using an acrylic display stand, and drilling the centre hole yourself ?
    [h=A dictionary is the only place where success comes before work]5[/h]Laura
  2. The Following User Says Thank You to mrs maggot For This Useful Post:
    webtrekker (21-03-2019)
  3. #12
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Quote Originally Posted by mrs maggot View Post
    Hi mrs maggot. What I do is, I order pre-cut acrylic (160mm x 100mm) and drill the holes myself using a step drill while the sheets are flat. I then bend them to the required angle in the hot wire bending machine I made for the purpose and round the corners with a drum sander.
    If the white acrylic turns out to be sublimatable, then I'll print the image before drilling and bending, making it an easier job in the press. Also, buying in pre-cut sheets is a lot cheaper than buying acrylic stands.
    Attached Images Attached Images
  4. #13
    Join Date
    Dec 2009
    Location
    Posts
    3,365
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    AAh sorry, I misunderstood your original post
  5. #14
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Wink
    Well, what a revelation! ...
    My 3mm cast acrylic samples arrived today and I wish I'd known about this years ago. I didn't realise you could sublimate directly to acrylic without speacial coatings, and I certainly didn't expect the results to be so good!
    These photos don't do it justice, but the print is densely coloured, sharp, and was easily pressed at 190 °C for 60 secs, light pressure, (the same settings I use for aluminium).
    The finished sheet was slightly bowed but was easily reheated and flattened. I don't have an old, defunct heat press that I could use as a cooling press so I'll just have to rig up something of my own.
    I can see loads of new opportunities here ........................!!!
  6. #15
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    I don't want to labour the point, but this could be a game changer for me.
    I've often seen thin acrylc sheet and items for sale 'for sublimation' and they are a lot more expensive than ordinary cast acrylic sheet, which led me to believe they were specially coated or something. Well, now I know that acrylic doesn't need to be coated I can make everything myself much cheaper and can have my own range of unique products which will be unavailable from any dyesub supplier.
  7. #16
    Premium Member
    Join Date
    Nov 2011
    Location
    Bishop Auckland, County Durham
    Posts
    4,280
    Downloads
    0
    Uploads
    0
    Mentioned
    5 Post(s)
    Tagged
    3 Thread(s)
    You should never be scared to just try putting something in the heat press with a transfer and see if it works or not ... we've tried alssorts, inc cast acrylic a few years back now (am sure I did mention in a few times)
  8. The Following User Says Thank You to pisquee For This Useful Post:
    webtrekker (26-03-2019)
  9. #17
    Member
    Join Date
    May 2013
    Location
    London
    Posts
    628
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by webtrekker View Post
    I am also like you ..I hate these sellers selling ordinary stuff very expensive as sublimation blanks ..Good example is Sublimation Canvas I bought from a subli suppliyer they were around £1.5 per A3 sheet but if you buy them in rolls as just normal poly canvas 1m would cost only £1 and sublimate even better than the so cold subli canvas lol..
    BTW I have done something similar to you clocks using my UV printer never know these would sublimate though..
  10. The Following User Says Thank You to Ravisteam For This Useful Post:
  11. #18
    Premium Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,369
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    That was the easy part. The fun starts when you want to form and drill it into shape.
  12. #19
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Quote Originally Posted by GoonerGary View Post
    Haha, yes, I find it easy to drill with a step drill. As for forming, I can put sharp bends into the sheet at any angle with my hot-wire bending machine, but haven't tried forming into othe shapes, such as S-curves, etc.
    One of my step drill bits ...
  13. #20
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    A slight problem ...
    The acrylic sheet SHRINKS in size slightly when heated and cooled. On my sample of 160mm (L) x 100mm (W) x 3mm (D) acrylic it shrank by just over 1mm in the width and 2mm in the length. Not an issue for me, but worth knowing if you work to exact dimensions.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
