Hi all.
I am completely new to this so hopefully having read through some of the posts and with help I can have a go.
I recently bought a cameo sillhouette and although enjoying it cant help but think I could do more with sublimation.
I have looked on ebayb etc but most seem to have problems with heads blocked so think I would be better buying new.
The sawgrass sg400 looks to be the ideal starter machine ( the cheap epsons look as if they will cause me problems).
Is this a good place to start and I think I saw trupix paper recommended.
Would you recommend any firm to buy from I used mdp for my first vinyl order and although quick to deliver i need to make sure i dont order different type sheets as they all come together (so hard to tell which is which all htv).
Would I be best sticking with sawgrass inks or use ink Express although it will come with a set of cartridges so would I need to do anything if I changed over after?
I have an old Joy's heatpress which may be ok until I can get a better newer one although I have no idea how to set it up in the menu again recommendations welcome for a different one.
Sorry for all the questions but as a newbie I am still learning and have enthusiasm.
Thank you for reading through this.
Jason
