User Tag List
Similar Threads
  1. SG7100DN has SC57000 error
    By theTbird in forum Printing Problems/Issues
    Last Post: 08-10-2019, 11:13 AM
  2. Sawgrass SG800 error 28114 error. Dodgy ink
    By kiko90 in forum Printing Problems/Issues
    Last Post: 12-06-2018, 12:47 PM
  3. Sold A3 Ricoh SG7100DN Printer
    By UK Printed Mugs in forum Buy It, Sell it, Give it away!
    Last Post: 08-05-2017, 10:18 AM
  4. Wanted Ricoh SG7100DN dye sub printer
    By Violetsub in forum Buy It, Sell it, Give it away!
    Last Post: 19-08-2016, 01:16 PM
  5. ICC for Ricoh SG7100DN with no SUBLIJET
    By kasoaparte in forum Printing Problems/Issues
    Last Post: 20-03-2014, 11:29 AM
Results 1 to 4 of 4
  1. #1
    Junior Member
    Join Date
    Apr 2019
    Location
    Littlehampton
    Posts
    2
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question SG7100DN Error 20222
    Hi,
    I recently bought a setup that included an SG7100DN with Sublijet cartridges (out of date and empty).
    As the printer was unknown and well out of warranty I went with refillable cartridges for it (Amazon) and dye-sub inks.
    The printer is communicating with both the MacBook and my laptop and I successfully flushed the lines with de-ionised water... so far, so good, but the system was telling me the waste ink tank was full, so I replaced it.
    On installing the refillable cartridges the printer goes through the initialisation for a few minutes and then stops with SC20222, suggesting turning off and on again. I've repeated the process a few times but always the same. Ricoh didn't recognise the code but I found a service manual online and bought the download. the code points to Tank 2 not achieving negative pressure. What I then did was swap the cyan refillable for the empty Sublijet one... restarted and the error was gone. I swapped them again and the error returned... repeated with the Sublijetcartridge, error was gone.
    Great! thought I.
    I contacted the seller and they were very helpful and sent me another set of refillables as well as a bottle of cyan to replace that used.
    Once it arrived I fitted the new cyan and... SC20222 was back. Just for good measure I put the Sublijet cartridge in and the error was gone.
    I've tried a couple of Ricoh service companies but they both say they no longer support the printer.
    I'm left with three options right now:
    1. Buy a single Sublijet cyan (approx £35) and hope that the rest of the printer is okay
    2. buy a new printer.
    3. ask you nice people for advice/experiences.
    I paid £50 for the printer and have spent about £85 on inks, cartridges and waste tank so I'm about £130 - £140 in on this machine.
    Thoughts, anyone?
    Steve.
  2. #2
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Are you sure the cartridge vent plug has been left open?
  3. #3
    Junior Member
    Join Date
    Apr 2019
    Location
    Littlehampton
    Posts
    2
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes. One of the things I checked when I filled them as I wasn't sure if they were to be open or not (thank you YouTube. ;) )
  4. #4
    Supplier
    Join Date
    May 2019
    Location
    Wolverhampton
    Posts
    141
    Downloads
    0
    Uploads
    0
    Mentioned
    9 Post(s)
    Tagged
    21 Thread(s)
    The SC20222 on the RICOH printers was listed as a 'Print head failure' in the old service manual / PDF list I had. Sadly I never found a definitive fix for the problem. There was a print head reset process that did fix the issue on one of our old SG3110DN but on 3-4 others it didn't work. I believe the failure occurs by the printing head overheating, usually from a blockage due to lack of use.
    Annoyingly there is no definitive list of RICOH service error codes, descriptions or fixes online. Not that I have ever found.
    Alex
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
