User Tag List
Similar Threads
  1. Sold Epson P600 A3+ Sublimation Printer with refillable carts
    By UK Printed Mugs in forum Buy It, Sell it, Give it away!
    Last Post: 30-03-2019, 06:32 PM
  2. Epson SC-P600 custom ink set RIP
    By jacekoj9 in forum Printers
    Last Post: 25-09-2015, 06:36 AM
  3. Sub Inks for Epson A3 printer L1300
    By Helen in forum General Dye-Sub Chit Chat
    Last Post: 19-04-2015, 02:45 PM
  4. epson inks
    By stuart in forum Buy It, Sell it, Give it away!
    Last Post: 05-03-2012, 07:33 PM
Results 1 to 6 of 6
  1. #1
    Junior Member
    Join Date
    Nov 2016
    Location
    york
    Posts
    4
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Need some advice regarding Epson p600 original inks.
    Hi I recently bough a Epson p600 for sublimation so have no need for the original set of inks that came with the printer. My question is can I sell these inks on and would they work in another Epson printer which has already had inks run through it. As I've been told that setup inks will only work in new printers and will not be recognised in a printer already flushed with inks? Can anybody shed light if this is true? I gather they will be less ink in these cartridge's but surly a Epson p600 will recognise these as original carts and run with them...
  2. #2
    Premium Member UK Printed Mugs's Avatar
    Join Date
    Aug 2014
    Location
    Poole, Dorset
    Posts
    2,113
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Good question and not one I can answer. Just wanted to say how good the P600 was for us in terms of sublimation.
  3. #3
    Junior Member
    Join Date
    Nov 2016
    Location
    york
    Posts
    4
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Totally agree, I'm super impressed with the results and converted to continuous ink system and massive saving in cost over the Sawgrass so would recommend to anybody thinking of upgrade. Back to my question I've advertised my original inks on ebba but had a guy saying they will not work on used systems as these inks are only setups? I've checked the net but not found anything to confirm this and was curious if anybody on here could enlighten me.
  4. #4
    Member
    Join Date
    Dec 2015
    Location
    FR
    Posts
    173
    Downloads
    2
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I always keep original inks in case I have a problem. You can always put them and see if the problem comes from your sublimation ink and/or cartridges. Once I thought my 1500W was dead, actually it was the refillable cartridges, as the original ones worked fine, just had to buy new refillables.
    Also, I think Epson requires you to send them the printer with original ink inside for warranty.
  5. #5
    Supplier
    Join Date
    May 2019
    Location
    Wolverhampton
    Posts
    141
    Downloads
    0
    Uploads
    0
    Mentioned
    9 Post(s)
    Tagged
    21 Thread(s)
    Sadly the original ink cartridges that are supplied with most desktop A4/A3 Epson printers are 'Setup' cartridges. These have a different microchip fitted to the front and so will only work in a brand new printer i.e. one that has never had inks installed.
    They still have a value to them but as they can only be used by someone with a brand new / out of the box SCP600 the potential buyers are few. The physical ink could be drained from them and used in refillable ink cartridges / CISS but would only be around 20-25ml per colour so again value is limited.
    I hope this helps.
    Alex
  6. #6
    Supplier
    Join Date
    May 2019
    Location
    Wolverhampton
    Posts
    141
    Downloads
    0
    Uploads
    0
    Mentioned
    9 Post(s)
    Tagged
    21 Thread(s)
    Quote Originally Posted by malkram View Post
    As Malkram said, it is worthwhile keeping the original inks as a back up for your warranty, given their low value as well it is the best option here.
    Alex
Posting Permissions
  • You may not post replies
  • You may not edit your posts
