User Tag List
Similar Threads
  1. Horizontal Lines / Veritcal bars on prints using Ricoh Printer SG7100DN
    By Lebowski in forum Printing Problems/Issues
    Last Post: 02-03-2019, 03:35 PM
  2. Faint horizontal lines on prints - DNP DS620
    By Ventmore in forum Printing Problems/Issues
    Last Post: 02-08-2017, 11:26 PM
  3. horizontal lines help
    By gorgall2 in forum Printers
    Last Post: 15-12-2016, 09:12 AM
  4. Epson 9880 Banding/Horizontal Lines
    By Justin in forum Printers
    Last Post: 06-03-2016, 09:59 PM
  5. Vertical or Horizontal
    By Charlie_ in forum Mug Presses & Ovens
    Last Post: 23-07-2012, 07:32 PM
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
  1. #1
    Junior Member
    Join Date
    Apr 2019
    Location
    Uk
    Posts
    15
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Horizontal lines on mug after sublimation.!!please Help!!
    Hello
    I am very new to sublimation business.! I have brought this machine and everything but when I was using this last night for very first time I wasted about 30 mugs.!! As after printing on sublimation paper image looks normal but after heat press I get horizontal lines across image.!! I am very worried about as I spend fortune on it!! Please see attached photo for your kind reference!!
    Please help.!!
    Attached Images Attached Images
  2. #2
    Member
    Join Date
    Jan 2015
    Location
    Dublin
    Posts
    68
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Check the paper print, there is probably banding on it. Print out a nozzle check make sure there are no missing bars.
    Sent from my K10 using Tapatalk
  3. #3
    Junior Member
    Join Date
    Apr 2019
    Location
    Uk
    Posts
    15
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi
    thanks for quick reply!! I done nozzle check and that’s fine!! Lines only appeared after heat press.!
    any advice please.?
    Quote Originally Posted by cyprian.costelloe View Post
  4. #4
    Member
    Join Date
    Jan 2015
    Location
    Dublin
    Posts
    68
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok, you have to find of the issue is with mug or the paper/printer. So if you take your image that you have printed, print it again but this time turn it 90 degrees and print the mug again, hopefully you have a clear space so you can use the same mug again. If the lines are vertical the problem is probably the printer/paper. If the lines are horizontal again..you are looking at the mug coating or the press.
  5. #5
    Junior Member
    Join Date
    Apr 2019
    Location
    Uk
    Posts
    15
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    do you think anything to do with heat press pressure for mug or temperature etc?
  6. #6
    Member
    Join Date
    Jan 2015
    Location
    Dublin
    Posts
    68
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Heat and pressure problems usually produce fading or poor colours. So the edges would not print or print poorly or there could be patches within the art. To be honest I would be blaming the printer initially, looking at poor ink flow.. Depending on the printer...do you have the little bungs removed from the carts to let the air in. That kind of thing.
    What you have is very consistent across the image. So if it is not the printer might be the coating on the mug or paper.
  7. #7
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    What printer are you using?
  8. #8
    Junior Member
    Join Date
    Apr 2019
    Location
    Uk
    Posts
    15
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by webtrekker View Post
    Hi
    Thanks for reply! I am using Epson WF 2630 with sublimation ink.!!any specific setting for printer I have to do for sublimation.?
  9. #9
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,257
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    Those lines are very 'definite' so I would expect if it's the printer you'd see the lines clearly on the print, what mug press are you using? Could be element marks...is your pressure too high?
    If there's no sign of lines whatsoever (look closely) then it has to be the press.
  10. #10
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,257
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    Quote Originally Posted by Jesh2002 View Post
    Hi
    Which inks? Have you set your software and printer settings up properly? Profile?
    My money's on the printer.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
