User Tag List
Similar Threads
  1. Horizontal Lines / Veritcal bars on prints using Ricoh Printer SG7100DN
    By Lebowski in forum Printing Problems/Issues
    Last Post: 02-03-2019, 03:35 PM
  2. Faint horizontal lines on prints - DNP DS620
    By Ventmore in forum Printing Problems/Issues
    Last Post: 02-08-2017, 11:26 PM
  3. horizontal lines help
    By gorgall2 in forum Printers
    Last Post: 15-12-2016, 09:12 AM
  4. Epson 9880 Banding/Horizontal Lines
    By Justin in forum Printers
    Last Post: 06-03-2016, 09:59 PM
  5. Vertical or Horizontal
    By Charlie_ in forum Mug Presses & Ovens
    Last Post: 23-07-2012, 07:32 PM
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
  1. #21
    Junior Member
    Join Date
    Apr 2019
    Location
    Uk
    Posts
    15
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by cyprian.costelloe View Post
    Put up a picture of the paper print you did the mug with, the used one.
    Sent from my K10 using Tapatalk
    i just checked and noticed used picture also got lines across.!! Which wasn’t there before heat press!!
  2. #22
    Member
    Join Date
    Jan 2015
    Location
    Dublin
    Posts
    68
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok so your printer is the problem. Check the carts did you remove the rubber bung?
  3. #23
    Junior Member
    Join Date
    Apr 2019
    Location
    Uk
    Posts
    15
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    but how come print on paper was nice without any lines and after process there are lines on paper and mug.?
  4. #24
    Member
    Join Date
    Jan 2015
    Location
    Dublin
    Posts
    68
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You are not getting enough ink on The paper, if you were printing a darker image it would be more obvious.
  5. #25
    Junior Member
    Join Date
    Apr 2019
    Location
    Uk
    Posts
    15
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thanks.!! I will have to double check all printer setting again!!
  6. #26
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,257
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    I've responded several times but you don't seem to be paying any attention :-)
    You need a profile and you need to know that the inks will be consistent. You can check the settings a hundred times but without a profile your images will never look right.
  7. #27
    Member
    Join Date
    Jan 2015
    Location
    Dublin
    Posts
    68
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi Justin, I agree that the inks and profile are important going forward but he needs to get it printing first even if the colours are way off.
  8. #28
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,257
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    But it wont print properly without the profile so why bother? Get the profile in and then set everything up or you're just wasting your time surely?
  9. #29
    Member
    Join Date
    Jan 2015
    Location
    Dublin
    Posts
    68
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No, the profile just tells the printer how much of each ink tho lay down to get the colour you want. So if you print with the wrong profile the green you get may not be the green you were expecting.
    To do it properly you really need to also calibrate your monitor so everything is singing from the same songbook
  10. #30
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,257
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    I'm aware of what a profile does I'm just stating that without a profile the colours won't be right so no matter how much you play with the settings it won't print properly until you install a profile.
    The OP hasn't responded directly to my questions for some reason, make of inks, press etc. so I can't offer any more help.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
