Old Ricoh, Dye Sublimation Supplies sublisplash ink and new paper from Ink Experts. All through the Sublisplash Driver supplied by Dye Sublimation Supplies.
Seriously bad banding but clear nozzles.
Any ideas?
Any ideas?
This is with the setting now set to high quality
Is there a head alignment feature on your printer?
Was there much change required in alignment?
Have adjusted still same result
Which model printer? Does it have the power flush feature?
The Ricoh 3110
Test print from the machine
This issue looks like it may be the 'dithering' issue. I can't recall the exact cause or fix but I am fairly confident it was a driver / software issue causing the printer / printing head to dither whilst printing.
When I use my SG3110DN I will usually set the paper type to Glossy and Quality Priority, I use the standard driver rather then Powerdriver or the Sublisplash one. I may be worth trying to printing using the standard driver to see if this resolves the issue?
Alex
