Join our Premium Membership now and save with Xpres, Listawood, Ink Experts, Ink Express and more! Just Ŗ10 per year.....Click the Membership link above.....
User Tag List
Similar Threads
  1. Epic fail mugs....vacuum press st3042
    By carolm1a in forum General Dye-Sub Chit Chat
    Last Post: 01-05-2017, 07:12 PM
  2. 3d Heat Press Vacuum Pump Problem
    By ijoycheckers in forum Heat Presses
    Last Post: 18-12-2016, 09:43 AM
  3. 3D Vacuum Heat Press - new model ST-2030
    By pawelz in forum 3D Sublimation
    Last Post: 17-05-2016, 04:23 AM
  4. Advice for timings st-3042 3d vacuum heat press
    By Reading-Print in forum 3D Sublimation
    Last Post: 29-04-2015, 12:25 AM
  5. ST-3042 vacuum heat press warm up times?
    Last Post: 30-03-2015, 09:21 PM
Results 1 to 3 of 3
  1. #1
    Junior Member
    Join Date
    May 2017
    Location
    Radziejķw
    Posts
    1
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Vacuum 3d Heat Press - mugs problems
    Hi :)
    What is the best temperature and time for one mug 11oz to be made properly in a Vacuum heat press 3d? And how to set the temperature and time when I want to do e.g. 2 or 6 or 14 mugs at a time? With the settings of 195 degress/9 minutes I get a blurred imprint.
    Of course, I use tape and silicon clamps.
    Thanks for the all tips!
    Mikolaj
  2. The Following User Says Thank You to miken12 For This Useful Post:
    socialgiraffe (30-05-2017)
  3. #2
    Member
    Join Date
    Jul 2018
    Location
    Coventry
    Posts
    38
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Same question...
    I have the 3d ST-3042 and for 9 mugs I use the following settings: 170C (the supply recommended that because the machine upgrade the motherboard the temperature cannot go over 190C. By setting the temperature on 170C once I put the mugs on the machine, the temperature goes up to 180C) and 14,3 minutes and I notice that the mugs get burn at the top when is full printing. Then, I tried 160C (to rich 170C) with the same time and same results...
  4. #3
    Member
    Join Date
    Jul 2018
    Location
    Coventry
    Posts
    38
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just an update in case someone need the information.
    3D ST-3042 bought it from Signzworld UK.
    As per the machine motherboard is updated, Signzworld recommended that never set the temperature over 180ēC. So, I been told to use the following settings.
    When you are printing full artwork, only print maximum 6 mugs at the time by putting the mugs laying down (for a better quality printing) on the 3D ST-3042 tray. Temperature: 170ēC Time: 9 minutes.
    Personally, for 6 mugs full printing without any protection paper between the artwork and green wrap, I use:
    Temperature: 170ēC, Time: 8:15 minutes, Mugs placed based down (I never get good results placing the mugs laying down) and with the green wrap lined with the base of the mug
    For 6 mugs with protection paper between the artwork and green wrap:
    Temperature: 170ēC Time: 9:15 minutes
    I think for non full printed mugs 170ēC temperature and 9 minutes should be fine.
    I hope that helps
Posting Permissions
  • You may not post replies
  • You may not edit your posts
