User Tag List
Similar Threads
  1. can you print out a flag for me please ?
    By kris_hm in forum Member to Member Offers/Requests
    Last Post: 25-01-2016, 09:50 PM
  2. For Sale SENKO CAP PRESS plus plate press and newstar 40 vinyl plotter cutter
    By letsgo in forum Buy It, Sell it, Give it away!
    Last Post: 13-10-2012, 12:07 PM
  3. Garment Vinyl with an iron? (need to make a flag!)
    By AdamB in forum Vinyl & Flock
    Last Post: 25-07-2011, 10:51 AM
  4. Flag Vinyl?
    Last Post: 15-08-2010, 06:10 PM
  5. Heat Press Vinyl on top of Vinyl?
    By Stitch Up in forum Vinyl & Flock
    Last Post: 09-07-2010, 10:26 AM
Results 1 to 6 of 6
  1. #1
    Member Chris-P-Midlands's Avatar
    Join Date
    Jul 2015
    Location
    Melton Mowbray Leicestershire
    Posts
    64
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Heta press vinyl on to a flag ?
    Or even,
    Heat press vinyl on to a flag ?
    Can anyone offer advice please ?
    I have a customer that wants me to source an england flag, and then print (vinyl press) in the four corner squares. I am assuming that off the shelf flags are nylon, and my question is, would heat press vinyl be ok on this type of material?
    Do any of you have exp, and can reccomend heat settings, or a supplier for a flag will withstand the heat press?
    Thanks in advance.
    Chris P
  2. #2
    Member
    Join Date
    Mar 2015
    Location
    Oxfordshire
    Posts
    532
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did some polyester flags off ebay for a friend, quite large flags and it was a pita trying to apply large vinyl logo to them. Multi passes through heatpress due to sie I wouldnt bother again put it that way! You can out source it though to a flag printer.
  3. #3
    Join Date
    Jul 2015
    Location
    Posts
    64
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks mr gobby,
    much apreciated.
    I think I will reccomend a banner, :)
  4. #4
    Senior Member mrs maggot's Avatar
    Join Date
    Dec 2009
    Location
    kettering, northants
    Posts
    3,365
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The weight of the vinyl is an issue, as it will not fly properly if too much vinyl is added, you also get glue bleed as flags are thin, and would need to make sure you line your heat press, as otherwise you will have glue on every garment for days after. Dye sub works very well on flags. Same rules, line your press well.
    [h=A dictionary is the only place where success comes before work]5[/h]Laura
  5. #5
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    I have a separate cutter which I use mainly for print and cut jobs with my Canon inkjet. However, if I need to sub print to something (eg. Mylar sheets, Jet-Opaque etc) then I print to PDF (including registration marks) as my cutter software doesn't support ICC profiles. I can then do the sub print with Photoshop which handles PDF's well.
  6. #6
    Super Moderator Paul's Avatar
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,590
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    You can ask someone to print it on the eco-solvent printer. There is a flag material on roll specially designed for those printers.
    <-- How To Print Stuff BLOG
Posting Permissions
  • You may not post replies
  • You may not edit your posts
