Join our Premium Membership now and save with Xpres, Listawood, Ink Experts and more! Just £10 per year.....Click the Membership link above.....
User Tag List
Similar Threads
  1. Magnetic sheets in bn-20
    By Paul in forum Vinyl Cutters
    Last Post: 21-12-2017, 12:12 AM
  2. Magnetic signs
    By TonyM in forum General Dye-Sub Chit Chat
    Last Post: 16-11-2015, 01:17 PM
  3. Magnetic mat
    By A11kns in forum General Dye-Sub Chit Chat
    Last Post: 22-09-2014, 03:57 PM
  4. Anyone got any magnetic dye sub sheet?
    By SciArtImages in forum Member to Member Offers/Requests
    Last Post: 27-11-2011, 10:32 PM
  5. Magnetic sheet
    By SJL in forum General Dye-Sub Chit Chat
    Last Post: 09-05-2011, 10:08 PM
Results 1 to 4 of 4
  1. #1
    Premium Member Mrteajunkie's Avatar
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    69
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Magnetic sign cutting.
    So I sell a lot of magnetic door signs for cars and vans.
    And wondered how you all cut your signs to size?
    So for me.
    I have an old us cutter machine that I only use for this purpose.
    i have 1’000s of blades for it so it’s no issue for me if it blunts them.
    Even at full exposure the blade doesn’t cut all the way through the material but you can see the blade is just about to cut through.
    I set my machine to cut at super slow speed and the highest pressure it can and that seems to work fine.
    I have a curved edges template set so I just load the magnetic material and press cut then fold around the outside to break it away completely.
    I have seen people cutting with rulers and corner rounders etc and thought why?
    So what’s your way of doing it?
    Graphtec ce6000 40 & 60 cutters for my main business - Uk press and st150 mug presses - T-shirt press - Epson sublimation printer
  2. #2
    Premium Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    1,844
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Hi. I print & cut magnetic party invitations from printable magnetic sheet on a Silver Bullet cutter.
    I don't know how thick your vehicle signs are as I've never done that type of thing, but my cutter whizzes through 690gsm magnetic sheets like a hot knife through butter! One cut, right through, on less than half maximum pressure, and a cutting speed of 300mm/s (just under half the SB's max speed of 800mm/s). Blade wear is minimal. I've cut thousands of these invitations in the last 2 to 3 years and only onto the second blade!
    These are my mockups, (all my 'proper' pictures have customers personal details on), but they look identical in real life ...
    Attached Images Attached Images
  3. #3
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    69
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ah yes the stuff I use is 0.85mil vehicle grade so it’s thick ;)
  4. #4
    Premium Member Quinsfan's Avatar
    Join Date
    Nov 2013
    Location
    Bookham
    Posts
    1,122
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just cut by hand so easy and soft. Sharp blade straight through.
  5. The Following User Says Thank You to Quinsfan For This Useful Post:
    Mrteajunkie (14-06-2019)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
