Have you done a nozzle check? Also try printing the test page directly from the Ricoh menu and see how it looks.
Chrizdene (22-06-2019)
Something wrong there. Ricoh's will print quite happily from Photoshop. Mine has done nearly every day for the last few years.
Just to make sure...
1. You installed your Ricoh printer driver.
2. You installed the ICC profile to your system.
3. You DISABLED the setting in your printer driver that makes the printer manage colours.
4. You ENABLED 'Photoshop manages colours' in the Photoshop print dialogue and set your ICC as the active profile from the dropdown list.
If all of that is correct then you should be able to print successfully from Photoshop.
Hi thanks for all your replys. We have tried evrything an still not working correctly - Did you see the photos I uploaded to show what we were gettign when we print???? regards
