User Tag List
Similar Threads
  1. New here , just hoping to get some information
    By John105 in forum Printers
    Last Post: 22-08-2013, 10:42 AM
  2. Any information would be a huge help!! thanks!!
    By leanne in forum General Dye-Sub Chit Chat
    Last Post: 25-04-2012, 05:12 PM
  3. Conflicting times for mugs.
    By bikertec in forum Mug Presses & Ovens
    Last Post: 13-05-2011, 07:34 PM
  4. craft robo and a printer conflicting
    By jenthelemur in forum Printing Problems/Issues
    Last Post: 16-03-2011, 09:29 AM
  5. CONFLICTING REPORTS RE EMULSION
    By AJLA in forum Screen Printing
    Last Post: 21-10-2010, 05:53 PM
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,384
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    You are using the GENIE III settings which is a much quicker mug press.
    The Genie I and II settings are 200 degrees for 45-60 seconds which is about right for a standard mug press.
    A Genie III is as you have already said 190 @ 40 seconds.
    I have both a Genie II and Genie III and the III is a much quicker press hence the time and temperature difference.
  2. The Following User Says Thank You to socialgiraffe For This Useful Post:
    Mrteajunkie (30-06-2019)
  3. #12
    Senior Member Mrteajunkie's Avatar
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    1,088
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by socialgiraffe View Post
    So would you recommend 190c for 45 seconds to start or something different?
  4. #13
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,384
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    It kind of depends on your mug press, but I would say that unless you have one of these "quick" presses then yes, start at 190 for 45-60 seconds.
    I would normally go in the middle, so 190 for 52 seconds ish
  5. The Following User Says Thank You to socialgiraffe For This Useful Post:
  6. #14
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    What it all boils down to, as I said earlier, is that there are no hard and fast rules that will give you perfect results on your first try. You will have to be prepared to lose some water bottles during the 'experimental' phase. I've gone through loads of items until I have found the 'sweet spot' with regard to pressures, times and teperatures. Even when you have the right settings you'll find that sublimation isn't an exact science that produces the same results every time. There are just too many variables, including air temperature, humidity, cleanliness of the print and surroundings, ink spatter, banding, tracking marks, Brexit, the Russians, .............. to name a few!
    In fact, I've virtually given up now on sublimating mugs. I have more success with aluminium sheet, keyrings, polyester bags, etc and I'm doing better by selling higher-profit items that involve a bit of mechanical construction than the 'stack-em-high, sell-em-cheap' items that everyone else is selling.
  7. The Following User Says Thank You to webtrekker For This Useful Post:
  8. #15
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    1,088
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    The sublimation side is more of a because it’s wanted not for profit.
    i wouldn’t normally do mugs and things but so many of my regular customers asked for them.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
