User Tag List
Similar Threads
  1. Issues with colour reproduction.
    By ScotTs in forum Printing Problems/Issues
    Last Post: 30-11-2019, 03:24 PM
  2. ICC and colour issues
    By PamC in forum Printing Problems/Issues
    Last Post: 12-06-2019, 04:24 PM
  3. Colour issues
    By johna1954 in forum Printing Problems/Issues
    Last Post: 20-11-2017, 12:26 PM
  4. colour issues
    By mfacer in forum Printing Problems/Issues
    Last Post: 26-04-2017, 09:52 AM
  5. Colour issues
    By Quinsfan in forum Software
    Last Post: 18-04-2016, 09:31 PM
Results 1 to 10 of 10
  1. #1
    Premium Member
    Join Date
    Feb 2019
    Location
    London
    Posts
    21
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Chromalux colour issues
    Hi All
    i've been getting into ali panels recently, but I've not been happy with the results.
    Specifically, I've recently purchased Chromalux panels (used Wunderboard before) from Xpres.
    Their spec sheet says to press at 195C for 3min 8secs.
    What I'm getting is a brown overall tinge, and the blacks on a black background are really poor.
    The original image is spot-on, and prints perfectly on all the office photo printers.
    I use a Sawgrass 800 for the printing which *should* have a managed colour profile and prints everything else (mugs etc) perfectly)
    At Chromalux prices it's an expensive mistake to keep making, so I'd appreciate some feedback on where I might be going wrong, or how to fix the issues to get a decent - if not perfect - black.
    Attached photo with a regular print laying on the metal, which may help.
    Thanks in advance for any help.
    J
  2. #2
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    I use Sublimetals, not Chromalux, and press for no more than 60secs. I would imagine that pressing aluminium for over 3 minutes is a bit excessive.
  3. The Following User Says Thank You to webtrekker For This Useful Post:
    Jeremy Nako (14-09-2019)
  4. #3
    Senior Member Quinsfan's Avatar
    Join Date
    Nov 2013
    Location
    Bookham
    Posts
    1,196
    Downloads
    1
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Blacks normally turn brown from over cooking.
  5. The Following User Says Thank You to Quinsfan For This Useful Post:
  6. #4
    Premium Member
    Join Date
    Feb 2019
    Location
    London
    Posts
    21
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by webtrekker View Post
    It's Chromalux's recommended timings.
    I also use Sublimentals, but the sheets are less than half the thickness, so I don't think that comparing the two (in terms of timings) is a good comparison.
  7. #5
    Premium Member
    Join Date
    Feb 2019
    Location
    London
    Posts
    21
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Quinsfan View Post
    That was my thought as well.. but without spending a fortune testing different times (all of which would be different to Chromalux's recommendations) I was hoping someone would have some first hand experience.
  8. #6
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Quote Originally Posted by Jeremy Nako View Post
    Why spend a fortune? Cut a sheet into smaller test pieces.
  9. #7
    Join Date
    Nov 2013
    Location
    Bookham
    Posts
    1,196
    Downloads
    1
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Or just do lots of smaller prints on one sheet at different times, temps and pressure
  10. #8
    Senior Member
    Join Date
    May 2012
    Location
    Plymouth
    Posts
    1,895
    Downloads
    0
    Uploads
    0
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    I haven't printed chromalux for a few years, but I did spend a lot of time getting things right for me. I cut sheets down to get timings and temp sorted. The chromalux timings used to be based on having a nomex pad and a wicking cloth with prints from an epson 4 colour large format printer not sawgrass. Hence your timings will be completely different.
    Timings were also dependent on the size of the blanks. A2 took far longer than A4.
    So unless you are using exactly the same set up, you will not get their results with their time and temp.
    The results can be stunning, but you will need your set up to be spot on.
    I packed it in because I found very few photographers (yes professionals) understood colour profiling...those that did and followed a thorough work sequence were blown away with the results. Alas these were few and far between!
    Janners
  11. The Following User Says Thank You to JMugs For This Useful Post:
    Jeremy Nako (16-09-2019)
  12. #9
    Premium Member
    Join Date
    Feb 2019
    Location
    London
    Posts
    21
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    As has been mentioned, Chromalux sheets have different timings based on size, so cutting into smaller pieces for testing doesn't work.
  13. #10
    Senior Member
    Join Date
    May 2012
    Location
    Plymouth
    Posts
    1,895
    Downloads
    0
    Uploads
    0
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Jeremy, I cut sheets down to get a base time and temp. Once the image quality was sorted I left the temp unchanged and extended press times for larger sheets, this second bit was quite easy. Hence cutting sheets down can be beneficial.
    Janners
  14. The Following 2 Users Say Thank You to JMugs For This Useful Post:
    Jeremy Nako (16-09-2019), webtrekker (16-09-2019)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
