User Tag List
Similar Threads
  1. Siser C-Print Hi-5
    By socialgiraffe in forum Vinyl & Flock
    Last Post: 06-07-2017, 08:16 PM
  2. Siser or MDP Flex Vinyl
    By Bob @ Prestige in forum Vinyl & Flock
    Last Post: 15-12-2014, 01:04 PM
  3. This will be an easy one for someone!
    By scotty44 in forum Printing Problems/Issues
    Last Post: 21-06-2014, 06:47 AM
  4. Hello everyone, I'm new so go easy!!
    By badlydrawnblue in forum New Member Introductions
    Last Post: 13-05-2014, 09:01 AM
  5. Siser and Grafityp
    By bikertec in forum Vinyl & Flock
    Last Post: 06-04-2011, 09:28 AM
Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
  1. #31
    Member
    Join Date
    Nov 2019
    Location
    Frankfurt
    Posts
    134
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I tested this product months ago and it was a mess, totally failed in combination with my Epson printer. Here were several problems, the ink smeared my cutter badly and i let it dry for 15 minutes. Next problem was that the B transfer foil could not lift the easysubli foil, the adhesive was way to weak, had to throw away everything. But the worst thing was the print quality, it looked blurry as hell, more like an aquarel picture, no line sharpness at all. On youtube they say its better to sublimate the picture on the easysubli foil instead of print directly on it, will result in sharper images. Maybe i give it another try but the first was a classic fail, not impressed. I think the product works best with sawgrass and the siser inks. Another thing is that all colors on those matte flock like subli HTVs look like washed out a bit, black is not deep black, bad sharpness etc..
  2. #32
    Member Mini KickUps Champion
    Join Date
    Apr 2020
    Location
    accrington
    Posts
    41
    Downloads
    2
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    107358601_385234555797228_8199845291815648820_n.jpgI actually find it amazing to work with now. The ink has to be completely dry or the adhesion is terrible, also I rip the backing away really fast (odd but it works) I do use an sg800 with sublijet hd inks and I select the htv transfer vinyl setting. I have used it for several customers now and its great. high vis garment dyde will bleed into your design eventually, I need to experiment with lower temperatures to see if this always happens! Its work noting that for large logos you can simply peel the logo off the backing without the need for a transfer sheet. Also if you buy a roll it works out at around 90p per a4 sheet which is awesome. I use this material for tshirts and bags and Im hugely impressed.107820475_726154671532127_382590774624546561_n.jpg
  3. #33
    Member
    Join Date
    Nov 2019
    Location
    Frankfurt
    Posts
    134
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by billy8581 View Post
    WHat i dont like about those printable HTV for sublimation is the matte texture, it always looks a bit dull and not as sharp. Maybe in my case i have to use the normal paper selection for the least amount of ink. I only know that most people and even siser said that its best do not directly print on that foil, this only works really well with the siser ink. They suggested to sublimate on the foil, not print.
  4. #34
    Junior Member
    Join Date
    Sep 2020
    Location
    Bedfordshire
    Posts
    7
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    has anyone tried the siser easysubli using Epson (not a SG or easysubli/sublijet inks) im currently in the markety for a a3 sub printer and i was primarily going to be using easysubi for photo on tshirts so wants to ensure i invest in the best fit machine.
    also as mentioned you can sub onto the easysubli rather than print directly onto it. can you sub onto any white HTV? is the easysubli just unique that it can go through a printer?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
