User Tag List
Similar Threads
  1. Help! Ricoh printer not getting colours correct
    By Chrizdene in forum Printing Problems/Issues
    Last Post: 30-06-2019, 09:16 PM
  2. What's the correct amount of pressure?
    By gazfocus in forum Mug Presses & Ovens
    Last Post: 20-06-2016, 03:46 PM
  3. Is this correct?
    By grobbo in forum Mug Presses & Ovens
    Last Post: 08-03-2014, 08:51 PM
  4. Replies: 4
    Last Post: 08-11-2012, 07:36 PM
  5. Correct word for when you use sublimation on an item
    By WorthDoingRight in forum General Dye-Sub Chit Chat
    Last Post: 21-09-2012, 09:44 AM
Results 1 to 5 of 5
  1. #1
    Senior Member Stitch Up's Avatar
    Join Date
    Oct 2009
    Location
    Bridgend, South Wales
    Posts
    1,422
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How to Correct for Cutting?
    Good morning all
    Although I use Coreldraw quite often, I'm a little stuck with this one!
    The problem is hi-lighted in yellow - I don't want the 'criss cross' cutlines for obvious reasons.
    I'm not sure which Corel tools I should use to correct this for cutting.
    I'll try and attach the vector file if the forum allows.
    Any tips would be gratefully received - I did look on YouTube but couldn't find the help I needed.
    John
    Attached Images Attached Images
    Attached Files Attached Files
  2. #2
    Senior Member
    Join Date
    Nov 2015
    Location
    dorchester
    Posts
    1,193
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Don't use Corel, but in Serif the easiest/quikest way to do that would be to create a contour with the exact measure set to 0%/0mm. Remove the original text afterward.
    Otherwise you can edit the nodes, deleating some and joining others.
  3. #3
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    I use dedicated cutting software, SCAL5, where these problems don't occur with text.
  4. #4
    Senior Member Quinsfan's Avatar
    Join Date
    Nov 2013
    Location
    Bookham
    Posts
    1,196
    Downloads
    1
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    In coreldraw, select the text convert to curves and then weld the objects. Or you may need to select the text break apart text, then convert to curves, select all the objects and weld together.
  5. #5
    Join Date
    Oct 2009
    Location
    Posts
    1,422
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the replies guys. thanks to Iain for the phone call, all very much appreciated.
    The design isn't a font, I wish it was as the Corel tools make correcting these crossing lines easy :)
    All sorted now.
    Cheers
    John
Posting Permissions
  • You may not post replies
  • You may not edit your posts
