User Tag List
Similar Threads
  1. Roland SG 540 TrueVIS Printer vs Roland SPi 540 !!
    By Ravisteam in forum General Dye-Sub Chit Chat
    Last Post: 28-08-2018, 10:31 PM
  2. Roland Versaworks /Roland Library Swatches
    By Focus1 in forum Printers
    Last Post: 12-03-2017, 08:36 PM
  3. Buying SG 400 from BMS. Anywhere else better?
    By AletB in forum General Dye-Sub Chit Chat
    Last Post: 07-09-2016, 05:50 PM
  4. roland cx24 - buying advice please?
    By gavtheoldskater in forum Vinyl Cutters
    Last Post: 08-10-2014, 05:28 PM
  5. Replies: 45
    Last Post: 10-05-2013, 10:34 PM
Results 1 to 2 of 2
  1. #1
    Premium Member
    Join Date
    Jun 2019
    Location
    Staffs
    Posts
    69
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What to look for when buying a used Roland BN 20
    Hi a friend is selling an18 month old Roland BN 20 which has hardly been used. It's always been plugged in so has regularly done its maintenance cycles. Obviously going to look at a nozzle check but is there anything else that can be checked?
    Ta
  2. #2
    Member
    Join Date
    Mar 2015
    Location
    Oxfordshire
    Posts
    532
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There are 3 ink variants,the original then 2 & 3 which both dry quicker and are not as durable on garments. Check the cutting all works well and consistently across the width of the cutting bed at reasonable pressure settings. Inspect the cap station for cleanliness and any deformation of the rubbers (its a service item) obviously the nozzle check is most important as that costs couple grand to replace, it's a DX7 which is much higher quality than many and over-engineered in some respects given that larger models had lower spec heads. A stand with it might be useful if it comes with one. Check how full the the waste cartridge and inks are, set of inks is £320+vat. If its 18 month old it presumably had a service at 12 months as part of the warranty and if you want peace of mind take out Roland care though it isn't cheap.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
