User Tag List
Similar Threads
  1. Possible Pizza cutter printer issue fix - Epson WF2010 + WF7710
    By customgift4u in forum Printing Problems/Issues
    Last Post: 13-07-2020, 08:05 PM
  2. New Epson 24" Sublimation Printer - Epson SC-F 500 24
    By Justin in forum Press Releases/Announcements
    Last Post: 02-10-2019, 03:16 PM
  3. BLOCKED HEADS Epson WF7710
    By Bispham in forum Printing Problems/Issues
    Last Post: 27-06-2019, 07:18 PM
  4. Print head Alignment not working on wf7710
    By LRC in forum Printing Problems/Issues
    Last Post: 15-03-2019, 12:59 PM
  5. For Sale Epson B1100 Sublimation system, Xpres Mug Press 2000, Epson B42W
    By Spawn in forum Buy It, Sell it, Give it away!
    Last Post: 15-04-2011, 12:31 AM
Results 1 to 2 of 2
Hybrid View
  1. #1
    Junior Member
    Join Date
    Oct 2019
    Location
    Breda
    Posts
    1
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Need help with epson wf7710 with sublimation
    Hello guys,im new to this forum,si first of all thank you for reading my post. Hello to you all.
    My name is Roberto and i need some info and help.
    Im new into sublimation, my setup is:
    -Epson wf7710 printer
    -Sublinova inkt...starting with this ink
    -siser easy subli transfer vynil to print on
    -sublijet forever 202
    What im stuck with is, how to setup icc profile for my printer to start printing in the right color tint?
    Is this needed tp setup the icc profile?
    Which transferpaper to use. I saw a brand of jet stream and read good things on this forum about the output quality.
    Im in testingfase, so trying to start with siser easy subli and forever 202.
    Can i get a advice which sublimation ink to use for the epson 7710.im based in the nerherlands and not every brand is available here. Also not every brand of transferpaper is available here.
    Hope that you guys in the UK have experience with better products.
    Need some advice and help as a newbie.
    Thanks guys.
    Gr Roberto.
  2. #2
    Junior Member
    Join Date
    Oct 2017
    Location
    Newport
    Posts
    14
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi,
    What program are you using to print? Are you using illustrator? Photoshop?
    if you go to printer preferences then set the settings from there like plain papers, high quality then in advanced section select no colour management. Because in illustrator for example when you print it will be selected let illustrator manage colours. Then select your icc profile from the list assuming you have installed it. Hope this helps.
    It make sense to me after a bottle of wine.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
