Pretty easy to make looking at this if you have a stock image.
https://design.tutsplus.com/tutorial...hop--cms-24283
I've knocked up a quick 3D model of a 20cm clock with hands and movement. Here are a couple of rough renderings ...
Instead of rendering a final image, I can also render as a Photoshop PSD document with all the render layers separate which enables me to change face image, background, shading, etc from within Photoshop instead of having to render a new image every time I cjange designs.
that looks great webtrekker, thanks for taking the time to do that. So we could add a red second hand to this and make the clock a little thicker without too much work? Just want it to look as close to the actual product as possible (You know how customers are!)
webtrekker (24-03-2020)
Yes Justin, it would be no trouble to add a second hand or change the style and dimensions of all the hands to match a particular product. Thickness is also easily altered. I can also change the materials to reflect those actually used and can remove the centre button if a second hand is fitted. Views can be from any camera angle with lighting altered to produce the nicest shadows and highlights.
As said previously, a big plus is being able to produce layered mockups for Photoshop, enabling anyone to easily change face designs and colours or add a different background.
Brill, great work
While I'm on, and I know I may have posted this before, but a long while ago I coded a web clock to display IKEA RUSCH clocks that I used to make up with custom faces. The beauty of this was that I could show customers their design on a working clock (it uses the time setting of their computer) ...
[User Deleted]
This code could easily be adapted to display a raytraced mockup of a 20cm clock, face-on of course, not at an angle as that would require some serious coding.
The clock linked to is a little rough around the edges as it was just copied from internet images and not a raytraced model, but I think you'll see the possibilities.
Justin (24-03-2020)
i have couple like this
<-- How To Print Stuff BLOG
Here's a clock nearer to the 5mm thickness and with a red second hand. Obviously, the hands could be changed or resized to match the ones you use ...
[User Deleted]
That's great, many thanks for sharing those. Would it be possible to get the .psd file to take a look at please?
Justin (26-03-2020)
