User Tag List
Similar Threads
  1. Epson L805 need profile
    By Leadbelly in forum Printers
    Last Post: 24-12-2019, 07:07 PM
  2. EPSON L1800 eco Tank or L805 with CISS
    By Andrius in forum Printers
    Last Post: 19-06-2018, 09:24 AM
  3. Replies: 1
    Last Post: 14-09-2017, 03:33 PM
  4. Epson L805 Film ?
    By Nyckutz in forum Printers
    Last Post: 22-02-2017, 06:23 PM
  5. Replies: 5
    Last Post: 05-03-2011, 10:48 AM
Results 1 to 10 of 10
  1. #1
    Member
    Join Date
    May 2020
    Location
    Blackburn
    Posts
    87
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    L805 slanting printing
    So I am losing my mind I have spent days trying to figure out why my epson l805 isn't printing straight. It is like 1 mm out but once on the mug looks ridiculous and too obvious. I must have measured the paper to make sure it all straight and the measured the gaps between the design and edges.
    I am out of ideas. I have tried on mug paper horizontal and vertically, a4 paper but it still slants. It starts off fine but as you get to the back it slants to the left.
    I am completely lost at the moment please help.
  2. #2
    Senior Member Mrteajunkie's Avatar
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    1,103
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Are the paper loading guides tight against the paper in the tray?
    if it starts out slightly off then it will only get worse as it pulls through.
    from epson:
    • If your printouts are slanted, try these solutions:
      • Slide the edge guides against the edges of the paper.
      • Select a higher print quality setting in your printer software.
      • Turn off any high speed settings in your product software.
      • Align the print head.
      • Make sure the product is not printing while tilted or at an angle.
  3. #3
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,257
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    May sound obvious but have you tried different papers to see if problem persists?
    As a quick workaround (not solution) you could add reg marks to your mug designs and cut them straight.
  4. #4
    Member
    Join Date
    May 2020
    Location
    Blackburn
    Posts
    87
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have tried all of these even having the paper loose then tight I can make if worse but its like the back end flicks up
    Quote Originally Posted by Mrteajunkie View Post
    from epson:
  5. #5
    Member
    Join Date
    May 2020
    Location
    Blackburn
    Posts
    87
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I tried to rotate the design against the slant and even that didn't work. I have now tried to offset the paper to counter the slant but I am getting fading and it still isn't great
    Quote Originally Posted by Justin View Post
  6. #6
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    1,103
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Try using standard a4 and print something and post the results.
    at worst it could be a roller inside the printer not gripping the paper.
  7. #7
    Member
    Join Date
    May 2020
    Location
    Blackburn
    Posts
    87
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So I printed the same design 1 at top and 1 at the bottom of an A4 piece of paper. at the start it was 4mm away from the edge but the end of that print it was 3mm. By the time it started the next print it was 2mm and then when it finished 1mm. And to top it all off there is a pink haze from the blacks onto the white.
  8. #8
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    1,103
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    If you print a white square and as the paper is coming through can you pull it slightly and does it move easily on one side?
  9. #9
    Member
    Join Date
    May 2020
    Location
    Blackburn
    Posts
    87
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah it did feel as if the right side I was able to pull it a bit.
  10. #10
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    1,103
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Can you see the pinch rollers from the front or inside?
    Just check they both have the same clearance and the bar isn’t loose.
    You could also print something and when paper is in unplug the printer to halt it and then pull on the paper to check the roller pressure.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
