User Tag List
Similar Threads
  1. Freesub ST-210 double mug press advice needed please
    By Mach-One in forum Mug Presses & Ovens
    Last Post: 21-09-2018, 04:34 PM
  2. Heat press advice please
    By Inset in forum Heat Presses
    Last Post: 06-05-2016, 09:20 PM
  3. Heat press & mug press bundles - advice needed
    By Kubicixfactor in forum Heat Presses
    Last Post: 11-04-2016, 11:00 PM
  4. Mug Press Advice Needed
    By taz8130 in forum Mug Presses & Ovens
    Last Post: 22-04-2015, 08:45 PM
  5. Advice on Heat Press
    By peapod in forum Heat Presses
    Last Post: 11-11-2013, 01:10 AM
Results 1 to 4 of 4
  1. #1
    Junior Member
    Join Date
    May 2020
    Location
    Reading
    Posts
    24
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question Protection used when using flatbed heat press - advice needed
    Hi,
    I have seen that people have a Teflon sheet attached to the upper platen.
    And then they use a silicone sheet underneath the medium they are sublimating on and a silicone sheet on top of the medium they are sublimating onto.
    Is this normal practice or overkill?
    Can the silicone protection sheets be used more than once?
    What do you guys do?
  2. #2
    Member
    Join Date
    Apr 2017
    Location
    Maidenhead
    Posts
    165
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey SweetPea Ive just seen your location lol. I personally only use a teflon sheet to stop the colors sticking to the heat plate. or on the next print i find i get a ghost print. And if its a double sided item i also use teflon on the bottom so the image dont stick to the rubber mat.
  3. #3
    Junior Member
    Join Date
    May 2020
    Location
    Reading
    Posts
    24
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi Fletcher, Ha yes we live close (and even closer as Reading is the biggest town near me .. but I live some between Reading and Maidenhead). :) lol
    I didn't fully understand what you meant above. When do you find you get a ghost print?
  4. #4
    Member Mini KickUps Champion
    Join Date
    Apr 2020
    Location
    accrington
    Posts
    41
    Downloads
    2
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use a teflon sheet when im doing high vis items or sublimating and just cover with release paper at the top half
Posting Permissions
  • You may not post replies
  • You may not edit your posts
