User Tag List
Similar Threads
  1. Epson 1500w printing lines - help!
    By MissRecord in forum Printers
    Last Post: 05-03-2019, 01:09 PM
  2. Printing on fabric
    By sarahjayne in forum General Dye-Sub Chit Chat
    Last Post: 25-03-2016, 08:20 AM
  3. Vertical lines on printing
    By bycandlelight27 in forum Printing Problems/Issues
    Last Post: 26-05-2014, 02:13 PM
  4. Printed clogged? Printing lines...
    By asub in forum Printers
    Last Post: 30-08-2013, 04:02 PM
  5. Printing onto fabric stuff
    By picagiftuk in forum Printing Problems/Issues
    Last Post: 12-05-2010, 10:48 AM
Results 1 to 5 of 5
  1. #1
    Premium Member
    Join Date
    Feb 2017
    Location
    Reigate
    Posts
    44
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Fabric placemat - non printing lines
    Dear Hive Mind,
    I'm printing some dark grey placemats (double-sided stitched linen-look type) and the internal seam is creating an INCREDIBLY ANNOYING step in the fabric, which is resulting in a pale line around parts of the edge.
    I have been through about 20 mats trying to make 6 acceptable ones and am tearing my hair out. I've tried nomex felt, deep rubber mat, no mat, high pressure, low pressure, longer time, shorter time etc etc.
    Does anyone have any ideas before I throw the heat press and all the damn mats out of the window?
    TIA!
    Ruth
    PS I have withdrawn the design from sale as "way too much hassle" so I just need to get these 6 done and then I can calm down!
  2. #2
    Premium Member
    Join Date
    Feb 2017
    Location
    Reigate
    Posts
    44
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    IMG_2592.jpgPic of offending area...
  3. #3
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Sorry, but this will be of no help. I can't see a way you could get over this with normal sublimation and pressing. Maybe a DTG machine or similar would have done the job, but at what cost? The only way I think would work would be to redesign them so that you had a white border around the offending area, not the best idea though, I know.
  4. #4
    Premium Member
    Join Date
    Feb 2017
    Location
    Reigate
    Posts
    44
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, you're probably right. Frustrating tho - I would have concluded that it was a lost cause immediately if it wasn't for the first two or three, which printed absolutely fine, but were a bit overcooked. Hence trying to recreate the "correct" conditions. I print quite a few lighter coloured mats and they're generally fine.
    I'm currently cutting up a laptop sleeve to try to create a slightly raised area underneath the rubber platen bit, in the hope that it'll flatten the damn things out enough to print properly... At this rate I'll have spent 3x the order value just getting it sorted - argh!!
  5. #5
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Have to tried pre-pressing them with a LOT of pressure to try and flatten the area as much as possible before pressing the design?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
