User Tag List
Similar Threads
  1. Disable resting temp on freesub st210 mug press?
    By 0202 in forum Mug Presses & Ovens
    Last Post: 11-10-2020, 09:10 PM
  2. Xpres xp5013 mugs and freesub press settings
    Last Post: 06-08-2020, 10:11 AM
  3. Highly Recommended Mini Heat Press
    By UK Printed Mugs in forum Heat Presses
    Last Post: 16-11-2015, 05:04 PM
  4. Recommended printers
    By dawn77 in forum Printers
    Last Post: 07-08-2015, 11:46 AM
  5. Recommended Image Supplier for Kids T Shirts?
    By mikeoooze in forum Sourcing New Items
    Last Post: 28-04-2015, 03:43 PM
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. #1
    Member
    Join Date
    Sep 2020
    Location
    Midlands
    Posts
    93
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Freesub ST210 recommended settings?
    Does anybody else use the st210?
    I have been playing with the settings but just can't seem to perfect it.
    This attached image is at idle temp 110, bake 185 and time 100 seconds but it's still fading at the bottom.
    I've tried putting it up to 110 seconds but it always seems to be toward the bottom (using both presses)
    Can anybody recommend the settings they use?
  2. #2
    Super Moderator Paul's Avatar
    Join Date
    Sep 2009
    Location
    camberly
    Posts
    8,590
    Downloads
    12
    Uploads
    4
    Mentioned
    7 Post(s)
    Tagged
    6 Thread(s)
    maybe is the mug then? where you got them from?
    <-- How To Print Stuff BLOG
  3. #3
    Member
    Join Date
    Jan 2020
    Location
    Oldham
    Posts
    68
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Are you taping around the bottom of the mug? It could be gassing out.
    Sent from my moto g(7) power using Tapatalk
  4. #4
    Member
    Join Date
    Sep 2020
    Location
    Midlands
    Posts
    93
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by leealbi791 View Post
    I've just been doing the ends by the handle, should I tape the bottoms too?
    I've made sure it's pretty tight
  5. #5
    Member
    Join Date
    Sep 2020
    Location
    Midlands
    Posts
    93
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Paul View Post
    I think it's the press settings as it works great on my old 5 in 1 press.
  6. #6
    Member
    Join Date
    Jan 2020
    Location
    Oldham
    Posts
    68
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by NickH View Post
    I always tape the sides and along the bottom off the mugs when doing a full print mug.
    I also pre heat my mugs at 100°c for around 3 minutes and then press them at 190°c for 160 seconds .
    Doing this really helps with avoiding fadeout.
  7. #7
    Member
    Join Date
    Sep 2020
    Location
    Midlands
    Posts
    93
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks, do you just leave the in the press at 100 for 180 seconds then straight in at 190 for 160?
    It's strange as my cheap, chinese 5 in 1 press does them perfectly at 180 for 180 seconds after warming up with a blank mug in but I can't master the ST210.
  8. #8
    Senior Member Mrteajunkie's Avatar
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    1,088
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    I only tape by the handle never had a single issue.
    hows the pressure on the mug?
    I would expect that the mugs are not straight and the press is t touching the bottom as much as further up the mug.
    try increasing the pressure on the mug I think that will solve it.
    I would also consider changing mugs.
  9. #9
    Member
    Join Date
    Sep 2020
    Location
    Midlands
    Posts
    93
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks, pressure seems very tight.
    Thing is with a cheaper press and the same mugs, paper and ink they come out fine.
  10. #10
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    1,088
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    If the pressure is good and the cheaper press is working I would be sending the press back.
    Sounds like you have two faulty elements then but seems a bit extreme for two to be faulty.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
