I'm working with a latte mug style and created a template in Photoshop which basically has a warp bend of 24 degrees. The edge of the transfer sits perfectly with the edges of the top and bottom of the mug.
So far so good. However, the design itself is distorted...a vertical rectangle block running top to bottom within the design has a slight trapezium shape..it's not parallel. Is it possible to have a non distorted latte mug or will there always be a perspective issue?
