User Tag List
Similar Threads
  1. Chromaluxe sublimation help
    By bross1004 in forum General Dye-Sub Chit Chat
    Last Post: 01-11-2018, 06:24 AM
  2. Chromaluxe chipping
    By GoonerGary in forum Printing Problems/Issues
    Last Post: 24-05-2018, 07:44 AM
  3. Chromaluxe Panels
    By socialgiraffe in forum General Dye-Sub Chit Chat
    Last Post: 14-02-2014, 08:57 AM
  4. Sold Vinyl cutting machine, Flat bed heat press, Rolls of Vinyl, Cutting software+ more
    By Danni06 in forum Buy It, Sell it, Give it away!
    Last Post: 19-08-2012, 10:14 PM
  5. Chromaluxe panels
    By fredster in forum Sourcing New Items
    Last Post: 20-09-2010, 02:31 AM
Results 1 to 4 of 4
  1. #1
    Premium Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,369
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Chromaluxe Cutting
    I'm looking for someone capable of cutting down Chromaluxe sheets into custom shapes to a high standard. I came across this technical sheet about cutting by cnc. But I've read that other companies can use laser cutting which I thought would melt the coating?
    https://www.starttosublimate.com/search/cnc-routing
    I could try local engineering companies, but this seems to require specialist tools.
  2. #2
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,413
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    Sublimetals are a major supplier of custom-cut aluminium sheets. I believe they use CNC machines so I'd probably go down the CNC route myself.
  3. #3
    Premium Member
    Join Date
    Jun 2010
    Location
    Cambridge
    Posts
    2,369
    Downloads
    0
    Uploads
    0
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Sublimetals can't cut 1.1 metal. Chipped edges and hacked off guillotine corners are bit unprofessional looking. I need Unisub standard of cutting.
  4. #4
    Premium Member
    Join Date
    Nov 2011
    Location
    Bishop Auckland, County Durham
    Posts
    4,280
    Downloads
    0
    Uploads
    0
    Mentioned
    5 Post(s)
    Tagged
    3 Thread(s)
    You can laser cut, and it leaves a melted residue around the cut, which needs some elbow grease to remove (alcohol wipes help too)
    It also leaves a sharp/burred edge around the cut which needs sanding/buffing down
  5. The Following User Says Thank You to pisquee For This Useful Post:
    GoonerGary (09-02-2021)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
