User Tag List
Similar Threads
  1. D-gen direct to fabric static blowout
    By viol8ion in forum Printing Problems/Issues
    Last Post: 28-09-2020, 06:33 PM
  2. Looking for a Protective Cling Transparent Film.
    By Stitch Up in forum Misc. Printing
    Last Post: 27-11-2017, 04:01 PM
  3. Window cling stickers
    By A11kns in forum Misc. Printing
    Last Post: 25-02-2015, 07:00 PM
  4. Self Cling window stickers
    By sensor in forum Member to Member Offers/Requests
    Last Post: 26-10-2012, 04:23 PM
  5. Window Cling
    By fr3spirit in forum Misc. Printing
    Last Post: 20-05-2010, 12:14 AM
Results 1 to 5 of 5
  1. #1
    Senior Member Mrteajunkie's Avatar
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    1,103
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    anyone print to static cling?
    I have been printing a few bits to static cling (it’s the printable version) and had a few problems.
    1. Printed side onto glass surface: If left in place for more than a day it leaves ink behind on the glass and the cling becomes unusable again.
    2. Printed side facing out blank side to glass: If i use a squeegee to apply to a glass to get it flat. some ink scratches off the surface leaving white surface visible.
    I have tried printing draft mode and in high resolution with no difference.
    Am I doing something wrong?
    Roland BN-20
    Genuine Roland ecosol max inks
    leaving to dry overnight.
    Static cling from mdp
    https://www.mdpsupplies.co.uk/digita...ic_cling_760mm
    Any help would be fantastic.
  2. #2
    Senior Member
    Join Date
    Nov 2015
    Location
    dorchester
    Posts
    1,199
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Is your RIP set to 'overprint'? You could be laying too much ink down in whatever mode you are using.
    You would usually apply to the inside of a window with the ink away from the glass. Have you tried usinf a felt squeegee or even a teflon sheet to apply?
  3. The Following User Says Thank You to pw66 For This Useful Post:
    Mrteajunkie (21-04-2021)
  4. #3
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    1,103
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Im not sure where the overprint setting is?
    Im using versaworks v6.8
    I dont seem to have a profile for static cling im using generic vinyl, but there are some on roland do you think that would help?
  5. #4
    Senior Member
    Join Date
    Nov 2015
    Location
    dorchester
    Posts
    1,199
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    I don't use a Roland, but if it is anything like the Mimaki Rip then it will be on the same menu as the print resolution/quality.
    Profile might help.
  6. The Following User Says Thank You to pw66 For This Useful Post:
  7. #5
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,387
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    I use the Penstick Static Cling from Grafityp.
    Printed a few rolls in my time both on the clear and on the white. Never had an issue with the white using a gloss print setting in Versaworks and the Sign & Digital profile. The clear has always been reverse printed (I can print white and metallic on my VS) but the white is printed face on meaning the ink will come into contact with the glass. Even with full coverage the cling sticks to the window.
    One thing I do know is that I have always left two days plus to dry. Not sure if that makes a difference but only time I have had issues like yours is where I put the signage up too quickly.
  8. The Following User Says Thank You to socialgiraffe For This Useful Post:
Posting Permissions
  • You may not post replies
  • You may not edit your posts
