User Tag List
Similar Threads
  1. Graphtec CE6000 to Print & Cut
    By dazzul in forum Vinyl Cutters
    Last Post: 16-09-2021, 10:51 AM
  2. Carrier Sheet with Graphtec CE6000?
    By Justin in forum Vinyl Cutters
    Last Post: 27-04-2018, 05:46 PM
  3. For Sale Graphtec CE6000-40 - VINYL CUTTER
    By Nemo in forum Buy It, Sell it, Give it away!
    Last Post: 28-11-2017, 01:21 PM
  4. Graphtec CE6000-40 problem
    By kermit in forum Vinyl Cutters
    Last Post: 14-09-2015, 12:12 AM
  5. Graphtec CE6000 Cut settings?
    By tlworkwear in forum Vinyl Cutters
    Last Post: 11-06-2014, 03:23 PM
Results 1 to 5 of 5
  1. #1
    Member
    Join Date
    Sep 2014
    Location
    West Midlands
    Posts
    46
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Graphtec CE6000-60 Problem
    Hi everyone, I would be very grateful of any help that can be given. I do my cut lines using Coreldraw I then open the plugin Cuttingmaster 3. This has worked perfectly for me for years. However suddenly the cutter has developed a mind of its own. Upon setting the vinyl in the cutter as roll >front edge position my cutter begins cutting in one spot which is right on the edge of the vinyl. I can't see what it has done as it it literally on the right hand edge of the vinyl. My computer shows the normal screen for cutting master 3 and although the trace cut area is highlighted, when I click to do the trace nothing happens. It will not trace the cut line nor will it cut the design. PLEASE HELP!
  2. #2
    Senior Member Mrteajunkie's Avatar
    Join Date
    Nov 2016
    Location
    Devon
    Posts
    1,088
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by colmac01 View Post
    im of no help here as I can’t remember what caused it or what cured it.
    but I had a similar issue where it cut the whole 30cm x 1m design onto a 3mm strip.
    Have you tried the obvious like rebooting the machines?
  3. #3
    Senior Member
    Join Date
    Nov 2015
    Location
    dorchester
    Posts
    1,193
    Downloads
    0
    Uploads
    0
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    You could try cutting through Graphte Studio, instead of cutting master. Export your design from Corel as a 72dpi .eps file and re-open in GS.
    Alternatively try reinstalling the drivers and cutting master.
  4. #4
    Member
    Join Date
    Sep 2014
    Location
    West Midlands
    Posts
    46
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you, I think I've tried everything but thanks for your advise.
  5. #5
    Member
    Join Date
    Sep 2014
    Location
    West Midlands
    Posts
    46
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you, I appreciate your advise.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
