User Tag List
Similar Threads
  1. ST3042 plates
    By Phil7465 in forum 3D Sublimation
    Last Post: 14-11-2019, 08:41 PM
  2. Travels mugs using the st3042 oven
    By carolm1a in forum General Dye-Sub Chit Chat
    Last Post: 09-11-2017, 11:45 PM
  3. Epic fail mugs....vacuum press st3042
    Last Post: 01-05-2017, 08:12 PM
  4. 3D Large Heatpress ST3042 x 12 mugs
    By customprints in forum 3D Sublimation
    Last Post: 01-12-2015, 04:44 PM
  5. 3D Sublimation ST3042
    By ex0rcist in forum 3D Sublimation
    Last Post: 05-03-2015, 03:58 PM
Results 1 to 2 of 2
Thread: St3042 mugs
  1. #1
    Junior Member
    Join Date
    May 2021
    Location
    Southampton
    Posts
    11
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    St3042 mugs
    I got the st3042 from signzworld as I want todo top to bottom images and get slightly closer to the handles
    When I followed the suggested times and temps the mugs came out so pale
    After playing about, if I go 200 for 12 minutes for 2 mugs. I wrap lay on their side and rotate after 6 minutes this way the image seems perfect.. but that’s significantly hotter and longer than the manual suggests.. is this just a quirk of this machine?
    I also assume if I put 6 in it will need a bit longer?
    Sent from my iPhone using Tapatalk Pro
  2. #2
    Junior Member
    Join Date
    Jun 2024
    Location
    Boksburg
    Posts
    1
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, it seems to work well. I use 13 mins with a flip over inbetween and also find this works better then having the cups upright. This also works well for the metal type flasks. I add 30 sec onto the time for each cup multiple, so 13½ mins for two cups, 14 mins for 3 etc. this allows for the temp drop while flipping the cups.
    in addition to this I also use silicon bands at top and bottom to keep the wrap snug and tight.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
