User Tag List
Similar Threads
  1. help with heat press problems
    By davest in forum Heat Presses
    Last Post: 09-06-2014, 10:09 PM
  2. Heat Press problems
    By GoldRapt in forum Heat Presses
    Last Post: 02-10-2013, 04:50 PM
  3. Problems With Mug Heat Press!!
    By SilentAlf in forum Mug Presses & Ovens
    Last Post: 24-12-2012, 12:11 PM
  4. problems with heat press
    By giftsne in forum Heat Presses
    Last Post: 04-05-2011, 04:15 PM
  5. Problems with my heat press
    By DELLAROSE in forum Heat Presses
    Last Post: 19-08-2010, 09:41 AM
Results 1 to 5 of 5
  1. #1
    Junior Member
    Join Date
    Aug 2021
    Location
    Gloucester
    Posts
    12
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Heat press problems
    Hi all, just another little post from me 🙈 sorry to be a pain but I’ve watched so many YouTube videos and read so many threads and posts that are contradicting each other and so now I haven’t a clue.
    I just wanted to know.. if the bottom and top of mug is faded does that mean the temp is not high enough or time not long enough? Or the opposite?
    If blacks are printing brown does that mean the temp is too high? Or the time too long or both?
    Any advice would be greatly appreciated, thanks.
  2. #2
    Junior Member
    Join Date
    May 2021
    Location
    Southampton
    Posts
    11
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Fading at the bottom can be lack of heat in that area don't forget that the base of the mugs absorb heat so will be colder.. I pre heat my mugs for a minute or 2 at about 120c to get some heat in.. My press only starts the countdown when target temperature reached
    My blacks go brown with too much heat.. Than can be either time or temperature
    I use 180c for 185 seconds when preheated
    Sent from my SM-G998B using Tapatalk
  3. #3
    Junior Member
    Join Date
    Aug 2021
    Location
    Gloucester
    Posts
    12
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you for the info rgsearley. Do you preheat your mugs in the press with the design attached?
  4. #4
    Junior Member
    Join Date
    May 2021
    Location
    Southampton
    Posts
    11
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sartay View Post
    My press has a preheat function
    But before that press u used to put just the base in the press and full temp no image for about 30 seconds.. And let rest for another 30 if I could feel a little heat in the centre of the base I would press
    In my current press yes I pre heat image on as ink won't transfer at 110c
  5. #5
    Premium Member
    Join Date
    Jul 2021
    Location
    Ilford
    Posts
    60
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    To pre-heat my press you put in a blank mug, Close the press and allow to get to temp, then put in your mug with the image, that said as above you can / should preheat your mug, I use boiling water I pour in the mug, leave for 5 min or so and then apply the image after drying the inside and out.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
