User Tag List
gazfocus
Similar Threads
  1. halogen oven vs Sublimation vacuum oven
    By smiley_mug in forum Mug Presses & Ovens
    Last Post: 21-08-2023, 03:21 PM
  2. Single grey T required
    By Mugshots in forum Member to Member Offers/Requests
    Last Post: 13-06-2018, 05:34 PM
  3. Replies: 2
    Last Post: 08-12-2017, 08:27 AM
  4. Adkins Single Mug Press
    By Modeapparel in forum Buy It, Sell it, Give it away!
    Last Post: 13-02-2017, 08:19 PM
  5. Replies: 1
    Last Post: 04-10-2013, 09:26 AM
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
  1. #11
    Premium Member
    Join Date
    Oct 2015
    Location
    Lancashire, UK
    Posts
    253
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by socialgiraffe View Post
    Looking at the photo do a couple of things...
    Firstly, put a steel ruler (or something straight) to make sure there is no "air" where it blurs. If you are unsure what I mean then ask and I will post a picture.
    Secondly, if it happens, put the clamp to one side. Get another mug but turn the clamp upside down. If the blurring appears in the same place then it can not be the clamps, but if it is on the opposite side and at the bottom it would indicate the clamp has deteriorated.
    By the way, if I was knocking out this sort of design and not full wraps I would consider purchasing mug presses instead. Stand alone ones and have as many as 5-10 on the go at once.
    Interestingly, I did check the mugs with a steel rule and there is a gap where it blurrs. However, there’s also a gap on the side that’s printed good, just not as big a gap.
    The top picture is the side that’s blurred and the bottom picture is the side that hasn’t.
  2. #12
    Premium Member Tetris Champion, Space Invaders Champion, Asteroids Champion
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,384
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    I would say that I am about 90% certain that is your problem and the only reason you have managed to get some good prints is because of the quality of your mug wraps and pure luck.
    Using the green wraps in an oven is superb but your mugs must be perfectly straight with no gaps at all. If there are gaps as shown you are relying on hit and miss. You could try brand new wraps as they will be tighter, but its not the solution.
    You could also try the red silicon wraps as my understanding is that they are better at dealing with slight curves etc.
  3. #13
    Premium Member
    Join Date
    Oct 2015
    Location
    Lancashire, UK
    Posts
    253
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Do you know the best place to get the red wraps from? I had some samples from xpres of the Schulze ones but they are super thick and you need a tool to get them onto a mug. I wonder whether you mean the likes of what signzworld sell like the attached?
  4. #14
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,384
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    I do mean the ones similar to the ones sold by the companies you mention without the requirement of a tool.
    They are considerably more expensive, but on the plus side, once purchased you only need to replace the silicon and not the wire clamp.
  5. #15
    Premium Member
    Join Date
    Oct 2015
    Location
    Lancashire, UK
    Posts
    253
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Thanks. Will order enough for an oven load and see how they go :)
    Sorry @Jabman for hijacking your thread.
  6. #16
    Junior Member
    Join Date
    Mar 2020
    Location
    Seaview
    Posts
    13
    Downloads
    0
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gazfocus View Post
    No worries mate, it’s all good to know!
  7. #17
    Senior Member
    Join Date
    May 2012
    Location
    Plymouth
    Posts
    1,895
    Downloads
    0
    Uploads
    0
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Do you know the best place to get the red wraps from? I had some samples from xpres of the Schulze ones but they are super thick and you need a tool to get them onto a mug. I wonder whether you mean the likes of what signzworld/longforte sell like the attached?
    The clamps you have shown in your post are the type I used many moons ago on mugs and big ones on 1 litre steins. As the silicon stretched I just adjusted them. I bought a big sheet off ebay and cut it down when they eventually tore, super cheap way. I just popped them on by hand, so easy enough.
    Janners
  8. The Following User Says Thank You to JMugs For This Useful Post:
    gazfocus (14-01-2022)
  9. #18
    Premium Member
    Join Date
    Oct 2015
    Location
    Lancashire, UK
    Posts
    253
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Mug oven recommendations. Single or double fan…
    Quote Originally Posted by JMugs View Post
    Janners
    Thanks. I’ve ordered 16 as a test so I can do a full ovens worth and see how that goes. I’ve also got our local rep from xpres coming on Tuesday to pick up some of the failed mugs to take back to their HQ for further investigation.
    So far we’ve tried
    1. new wraps (still the green ones).
    2. printing the papers the other way (so changing the grain of the paper).
    3. Different paper (srace and trupix).
    4. Wearing cotton gloves to wrap to eliminate oily skin.
    5. Different timings on the oven.
    It’s 100% an issue with the mugs. The issue is xpres say we are the only ones reporting issues (probably we are the only ones using large quantities of mugs in ovens). If we used mug presses we likely wouldn’t have the issue as the mug presses would compensate for the lumps and bumps.
    Ps I tried to reply to your message about the ovens before Christmas but your inbox is full.
  10. #19
    Join Date
    Jun 2011
    Location
    Conwy, North Wales
    Posts
    4,384
    Downloads
    1
    Uploads
    3
    Mentioned
    15 Post(s)
    Tagged
    1 Thread(s)
    So here are a couple of options.
    You could turn the clamp "upside down" and try another mug. Print one mug at a time because if the mug is going to spoil it will spoil regardless of the quantity in the oven. So you may as well save a few pennies when looking at this.
    Also, as an option. Get Xpres to send me a box of mugs which I will l print for you. The design can be anything you like as I am not trying to "score" a box of mugs, but figured it will be a good way of seeing if the issue is your process or the mugs. If you want, ping me one of your most problematic designs and I will print that. Happy to do this for you as you have spent A LOT of money and still none the wiser. You need a completely independent viewpoint on this.
    If you have someone closer who is not having any problems printing and using ovens then give them a try if you prefer. The key factor is to only give them XPRES mugs and a design to try.
    Not sure if it was my Inbox you were referring to but it only has one message in it.
  11. #20
    Junior Member
    Join Date
    Mar 2020
    Location
    Seaview
    Posts
    13
    Downloads
    0
    Uploads
    0
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by UK Printed Mugs View Post
    We bought a dedicated 70l sublimation oven from "that company we are not allowed to say on this forum" which is FANTASTIC and is still available from alternative supplier Neil Brothers:
    https://www.neilbrothers.co.uk/subli...tion-oven.html
    That oven looks pretty good. Just a few questions if you wouldn’t mind.
    How many mugs do you manage to sublimate at a time?
    Is this an unbranded machine?
    Thank you
    Jabman
Posting Permissions
  • You may not post replies
  • You may not edit your posts
