Gloss side up for pressing ;)
Does the hot flex roll fit the width of the cameo 4 or so you have to cut to the mat size?
Originally Posted by soulclaimed Does the hot flex roll fit the width of the cameo 4 or so you have to cut to the mat size? By the roll hot flex is 500mm and a cameo is 305mm I believe so no. you can buy it by the sheet @ either 230 or 330mm
Forum Rules
