User Tag List
Similar Threads
  1. Aluminium drinks can
    By stevew in forum General Dye-Sub Chit Chat
    Last Post: 23-01-2021, 07:46 PM
  2. Aluminium water bottle issues - temperatures?
    By carolm1a in forum General Dye-Sub Chit Chat
    Last Post: 10-02-2018, 10:19 PM
  3. 0.5mm Aluminium
    By ArferMo in forum Printing Problems/Issues
    Last Post: 20-01-2015, 10:16 PM
  4. Aluminium Water Bottles - Possible issues regarding safety and quality
    By Justin in forum General Dye-Sub Chit Chat
    Last Post: 03-12-2014, 10:13 PM
  5. Epson D120 issues - I have two of them, each with different issues!
    By barryslip in forum Printing Problems/Issues
    Last Post: 21-01-2011, 02:15 PM
Results 1 to 5 of 5
  1. #1
    Junior Member
    Join Date
    Nov 2023
    Location
    Poole
    Posts
    2
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Aluminium Issues - Please help
    Hi. I am having real issues printing aluminium sheets and commerative shields from both subli metals and BMS.
    I had some issues mottled finish which I have sorted but every one of our tests all have the same problem where the very edge of the sheets are not transferring correctly. either faded or looking jagged edge. Some of the sheets do have a very slightly raised edge which I guess comes from the cutting of the sheets but especially the commerative shield just has a 1mm (ish) line around the edge which hasn't isnt showing the artwork.
    I have a pneumatic press and I am pressing 180 degrees for 80 seconds at 20psi with copy paper at the bottom, then the artwork sheet, aluminium sheet face down then copy paper with butcher sheet top and bottom. I seem to of tried dozens of different settings and whilst have eliminated other issues through testing every single press has left the same issue.
    I have read a couple of posts on here related and tried to use the recommendations (copy paper) but nothing works at all.
    Around 50 blanks down testing and no closer to a solution. Using sawgrass SG1000 with bypass tray and have use both S-Race paper and A-Sub
  2. #2
    Premium Member
    Join Date
    Feb 2013
    Location
    Chesterfield
    Posts
    75
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    We use a polyester fabric (Endura) over the top, I think Xpres sell it. It helps to absorb moisture to prevent mottling but also fills in any dips or edge defects in the metal to give an even print.
  3. #3
    Junior Member
    Join Date
    Nov 2023
    Location
    Poole
    Posts
    2
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi. Thanks for that. We actually ordered some from Nova Chrome on Saturday so hopefully that will help. What do you do in terms of layers? Paper, Metal, Print etc... Metal Down?
  4. #4
    Premium Member
    Join Date
    Feb 2013
    Location
    Chesterfield
    Posts
    75
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    We use a Teflon sheet at the base but anything to protect the base rubber from ink being transferred into it. Then we place the metal then transfer paper then Endura fabric on top. The dryer the paper, the better the finish. Use more pressure on the press if the edges are rough, this will allow the endura fabric to push the transfer paper into the raised edges and prevent any fading.
  5. #5
    Senior Member webtrekker's Avatar
    Join Date
    Sep 2016
    Location
    Northumberland
    Posts
    2,404
    Downloads
    0
    Uploads
    0
    Mentioned
    14 Post(s)
    Tagged
    3 Thread(s)
    I get best results by using the following layering:
    Couple of sheets of copy paper on the bottom
    Sublimation print facing upwards
    Aluminium sheet facing downwards
    A sheet of baking paper on top
    I press at 190°C for no longer than 60 secs and use very light pressure. I've never had edge problems and only ever used sheets from SubliMetals.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
