Loving the site Matthew and yes like everyone else it is slow
but then again so is Martin's
ask your host what the spec or your hosting is, they should be able to up the speed for you
Do you know if this is because customers just go elsewhere? I just counted 25 while the page showed nothing. If it wasn't your site and if I wasn't intent on looking at it, I'd have clicked away after 5 seconds. Once you've clicked away, there's no way to tell you that it's too slow.
The images are certainly a lot better than they were, with just two "banner.gif" images that are a bit weighty. They wouldn't cause this kind of delay on their own. Normally a web-page will start to load, even if it hasn't fully downloaded - unless there's a script that's designed to delay the display of the page until it's all ready to "pop" onto the screen. Is that the case here?
We have a few thousand registered customers and not one has complained, In march we has 126 register so it must not put that many people off.Do you know if this is because customers just go elsewhere?
I'm not sure about the script.Normally a web-page will start to load, even if it hasn't fully downloaded - unless there's a script that's designed to delay the display of the page until it's all ready to "pop" onto the screen. Is that the case here?
Matthew
we use a domain forwarding from the company we bought .co.uk from to the company we have .com with and hosting.
try typing www.alligiftor.com rather than the forwarding as i've just spoke to hosting company on live chat and she said it loaded on her computer is 2-3 secs
Matthew
even the .com loaded slow for me mate :(
but not as bad as the .co.uk
That took a count of 10-12. I then tried the .co.uk again and counted the same, so I don't think it's the forwarding that's the issue.we use a domain forwarding from the company we bought .co.uk from to the company we have .com with and hosting.
I've done a couple of other tests, including a couple of tracerts. Your .co.uk domain reaches the forwarder in no time at all (within reason, anyway), so there's nothing wrong with that. However, the .com domain keeps timing out - and this could well be what's leading to the delays now.
Did you know that your website is hosted in Denmark? I should have noticed that sooner as I have Flagfox installed, but I didn't. The tracert is timing out after it reaches IP address 83.221.128.4 - which is in Denmark - so that looks like your bottleneck. Of course it won't affect your host, because they're already in Denmark!
If your primary customers are in the UK, you would be best served to have your site hosted in the UK.
Great bright site but I havent even got onto a second page as the wait is painful. We are only on 1.5mb broadband. People are impatient and wont stop. Hope you get it sorted as it looks the biz.
Thanks, I'm gonna look in to new hosting soon, just got a lot on at moment with move and everything lolThat took a count of 10-12. I then tried the .co.uk again and counted the same, so I don't think it's the forwarding that's the issue.
Matthew
Your easiest option might be to go to the company that you registered your .co.uk domain with and buy some of their hosting. I think they're in the UK, aren't they? Then you could copy your .com site straight into the new .co.uk hosting.
You can then deal with the forwarding/transfer for the .com domain at a later stage, when you have the time.
It wouldn't immediately solve the .com delay, but the .co.uk should work much quicker right away.
That's what I'd be tempted to do.
