I've manged to change hosting comany, just waiting for it to be activated gone with www.1and1.co.uk
Hopefully i can transfer website over without having to build it again, i know how to do FTP, but when it comes to the MYSQL database i'm lost haha
Matthew
most good hosting companies will do it all for you ;)
Transferring MySQL data is simple enough so long as you have access to it (such as with phpMyAdmin).
Most cheap hosts won't do anything to help because they're just providing you with the space. It's up to you what you do with it.
Yeah i have access to phpMyadmin, just need to figure out how i change database properties in prestashop to point to new database.
Matthew
stick a quesiton on the prestashop forum, its really a brilliant place they will have you up and running in no time (but then being french running is their thing lol)
[h=A dictionary is the only place where success comes before work]5[/h]Laura
I'll have to do that, just downloaded phpMyadmin and not got a clue what to do with it or how to install it, it looks confusing there's lots of files haha
Matthew
You shouldn't need to "download" phpMyAdmin. If your hosting package is set up right, you should be able to login to it through your control panel. Then the Export option is there, which you use to download a text file of your MySQL tables. You then go to your new host, login to the phpMyAdmin that's provided there, and upload the text file. Simple.
As for Prestashop? I don't use that one but, with ZenCart, it's just a matter of changing the config files, IIRC.
I've managed to swap everything over to new host, hopefully website is quicker now
Please let me know www.alligiftor.co.uk
Matthew
super faster :)
