i can see the crease's in trousers no problem justin in photoshop - without touching any brightness prior to print stage - the trousers are a dark blue anyway - are they not ?
No problem on screen it's when I print I lose the detail, must be a print issue but seems strange.
time to calibrate screens ppl
Looks like you have them set on to bright...
Did you calibrated with munki buddy? or still using my profiles?
<-- How To Print Stuff BLOG
The man is a genius......
Everything now done with munki, will try yours again.
I noticed when calibrating with munki Color are great but if profiled on metal then it need to brighten up a bit. dont know why but is just little bit to dark and contrasty. Color still great tho.
What's best surface to use for profiling Paul? Polyester cloth?
I had best results when used xpress old tee :) with munki. need to add bit more contrast sometimes but this is better then to contrasty :) try it. i think you will like it that way... Have and scrap tee?
Yeah, did mine on vapor tees. Any chance you could email full size pic of this Paul?
