Have just replaced my R1800 with a B1100, as normal the settings avaliable have changed. Can someone let me know paper choice for this printer, I used archival matt before, but the 1100 doesn't have this not. Plain or matt?
http://sawgrasseurope.indigofiles.co...figuration.pdf
This should help you :-)
Matte paper settings
i use matte as well with mine :)
then photo
what paper you going to use? I use texprint and setings are: plain paper. Photo. If you use matt paper then to much ink will be delivered.
<-- How To Print Stuff BLOG
i use trupix with mine :)
That would never do, would it?
The best thing anyone can do is to run a bit of trial and error and see what works best for them. The Sawgrass profile is too generic to stick with hard and fast rules, because what works for one person might not work for another.
In the past, I've found that 'plain paper' setting doesn't deliver the quality, 'matte paper' biases the print towards green, and 'photo paper' biases it towards red - so I would change settings depending on the image I was printing.
Thanks for replys. Always good to hear that things are not a simple 1 2 3.
Did some sunscreens using photo & matte settings, perfect results. Am going to do some subli-flock today so hopefully all will be well.
