hi! I am looking for someone who could do low quantity of embroidered heat adhesive patches.
Any one can do that sort of think??
job:
about 9x5cm
2 colors
job:
about 9x5cm
2 colors
<-- How To Print Stuff BLOG
print low quantity of embroidered heat adhesive patches
contradiction in terms, print, embroider ... what?
You can buy Polyester blanks from Golden Finishes and sub what you want on to them.
I can embroider, or print, and then badge make, much depends on volume - as always, - the first few are definitely the most expensive, but they can get cheaper quite quick.
More info please.
sorry embroidered heat patches. what info do you need logobear?
Do GF still do them, the badges they have don't seem to suggest they are heat appliedprint low quantity of embroidered heat adhesive patches
More info please.
http://shop.goldenfinishes.com/produ...lar-badge/rr01
or am I not looking at the right one ?
I'm looking for some of various sizes for a football club
Woven badges are cheaper than embroidered, I beleive. These guys will give you a qoute http://www.franklins.co.uk/aboutus/index.asp Min quantity 100 peices. Probably between £1-2.00 each. Takes quite a few weeks for the process, from sample badge to receivieng the order.
The subli-flex from bms looks a good product for cheaper badge production?
Hi Paul,
I see that I am out of the thermal adhesive backing, - so not able to help at the mo, - it is very much a minority offering, OK if we are doing many dozen, a challenge if only a few.
For embroidery - we need an EMB file - conversion - we charge £25 and a few badges would typically be £8 each or so depending on stitch count. I can only interlock square/rectangular badges, not round/shaped.
I will be getting the adhesive backing sometime soon .....
[QUOTE=logobear;39471]. I can only interlock square/rectangular badges, not round/shaped.
QUOTE]
Thats my question answered then lol, I'm out :)
Paul put your image on a usb stick and give it to one of us going to the show and I am sure we could get a couple of samples from the print & Promotion show this weekend
I use the AFS System from Madeira, any size or shape badge can be done cleanly. Take a look at the P&P show next week.
Sharon
Problem is i ha some quotes and they way to high for that what i want. Iam looking for.heat adhesive patches so i can press on baseball caps. But by looking at the price of £7 each i am not going to do that :-(
