Just thought i would share this.
I brought some printable flex from BSM a few months ago and finally got around to trying it out today.
The sheets i brought were A4 so easly fitted into my standard Printer (epson dur-brite Ink) I printed via my Cameo machine so i could also get the reg marks so i could cut the outline correctly.
The image i used wasnt that great (dark , old blurry) but thought as it was just for a fun standard joke 18th t-shirt what the hell ill give it a shot.
OK so i printed it up , Cut it out and peeled the cut printed image from its backing sheet
"now i hear you say , pulled off its backing sheet?"
That right , its very sturdy stuff and doesnt need the sheet to be pressed it doesn't fold , stick or crease like normal flex , you place it obviously printed side up (the adhesive is on the side stuck to the backing sheet) onto the material to be printed and I personally placed some heat proof sheeting over the top to just protect stuff. 15 seconds @ 155 medium pressure , released press checked then further press for 5 seconds.
The over all finish was a easly stuck image vinyl quality and great looking. I will for sure be buying some more of these sheets the finished quality was 100 times what i was expecting.
Unsure if this will be helpful to anyone else but thought i would share anyway.
Lee
