Does any one know what is the thickest card can go though a silhouette cutter
It says it will cut chipboard, so i should imagine it will cut very thick card.
~~If you click here it tells you all the specs http://www.silhouetteamerica.com/med...pecs_cameo.pdf
Have cut 300gsm easily, but needs to be set on double cut.
