User Tag List
Similar Threads
  1. Silhouette Cameo
    By harlequeen in forum Vinyl Cutters
    Last Post: 02-07-2013, 09:12 AM
  2. Silhouette cameo
    By Lornem in forum Misc. Printing
    Last Post: 02-04-2013, 12:20 AM
  3. silhouette cameo
    By Craig in forum Vinyl Cutters
    Last Post: 12-09-2012, 09:36 PM
  4. Silhouette Cameo
    By bigj2552 in forum Vinyl Cutters
    Last Post: 09-06-2012, 09:08 PM
  5. Silhouette Cameo
    By gazza in forum Vinyl Cutters
    Last Post: 07-05-2012, 09:53 AM
Results 1 to 7 of 7
  1. #1
    Administrator Justin's Avatar
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,253
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    Silhouette Cameo - .dxf import
    My Cameo saved me again when i got (very badly) let down with a new cutter (that's another story!) What a great little machine, fantastic/simple software :-)
    Question is this, when I export in .dxf from CorelDraw and open in Silhouette software the image appears slightly larger and I have to scale it down. Anyone know what could be causing this?
    Also, I have to use the sticky carrier sheet for Xpres vinyl which surprises me, is this normal? If I don't use it the vinyl shifts.
  2. #2
    Senior Member
    Join Date
    Apr 2012
    Location
    Vale of glamorgan
    Posts
    1,113
    Downloads
    3
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Silouette Cameo is a god send!
    why cant they just have a patch or something which enables you to use other cutters etc, or simply make a nice 54" silhouette cutter
  3. #3
    Member
    Join Date
    Apr 2013
    Location
    St. Albans
    Posts
    290
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Any garment vinyl shouldnt need a carrier sheet Justin, Ive used xpres before without any issues. Stupid question but have you locked the rollers down? There is a little lever on the right hand side of the machine.
  4. #4
    Join Date
    Sep 2009
    Location
    Derbyshire
    Posts
    10,253
    Downloads
    7
    Uploads
    1
    Mentioned
    39 Post(s)
    Tagged
    7 Thread(s)
    That's what I thought, no need for the additional sheet. Definately got the levers locked down and it starts off ok but then starts to slip mid-cut :-(Spoken to MDS when I first bought it who weren't all that interested and tbh I've only just starting using again recently so haven't had a good chance to test the issue until now.
  5. #5
    Member
    Join Date
    Apr 2013
    Location
    St. Albans
    Posts
    290
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thats very strange.. The only time I have ever had an issue like that is when I have cut the vinyl myself to size and cut it too narrow. What size do you cut the vinyl down to? I cut 330mm wide just to be sure.
  6. #6
    Member
    Join Date
    Feb 2013
    Location
    Meath, Ireland
    Posts
    476
    Downloads
    1
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    if your buying pre-cut vinyl sheets, i often find that the ones I buy aren't cut properly and the width varies a bit. have had a couple of slips before, but usually solve it by moving the rollers in a notch on the cameo to be sure.
    with regards to the DXF files, the exact same thing happens to me. I export .dxf files from Illustrator, open in Cameo, and they are always a different size. for the work I do its not a huge problem, as my designs will generally be cut at different sizes anyway depending on what I'm doing. can see why it might cos some issues tho if you need your measurements to be very exact!
  7. #7
    Member
    Join Date
    Apr 2013
    Location
    St. Albans
    Posts
    290
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Normally the pre-cut sheets will be wider than the maximum cutting width of the cameo, at least for the places I have bought them from they have(MDP mainly). I always find buying the rolls better as you can control the width you want but when I first started out it was brilliant to be able to order a sheet of each colour for samples / testing etc.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
