User Tag List
Similar Threads
  1. Advice for timings st-3042 3d vacuum heat press
    By Reading-Print in forum 3D Sublimation
    Last Post: 29-04-2015, 12:25 AM
  2. new mug press advice?
    By spongerobinson in forum Mug Presses & Ovens
    Last Post: 01-12-2013, 10:06 PM
  3. Some Advice on swopping Mug Press For Flat Bed Press...
    By Lee in forum General Dye-Sub Chit Chat
    Last Post: 09-09-2011, 05:04 PM
  4. advice on this heat press combo
    By gavgav in forum Heat Presses
    Last Post: 23-08-2011, 05:11 AM
  5. Advice on new heat presses
    By Justin in forum Heat Presses
    Last Post: 19-01-2010, 08:53 PM
Results 1 to 3 of 3
  1. #1
    Junior Member
    Join Date
    Nov 2013
    Location
    UK
    Posts
    1
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Advice on Heat Press
    Hi All, I'm looking for some advice on buying a heat press for T shirts, I'm looking at a Stahls 28cm x 38cm, would that be large enough? The larger ones are out of my budget. Also does anyone know anything about Senko heat presses and if they are any good?
    Cheers
    James
  2. #2
    Senior Member bms's Avatar
    Join Date
    Oct 2009
    Location
    Dorset
    Posts
    4,079
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by peapod View Post
    Cheers
    James
    Large enough for what? If you've only got an A4 printer then yes. If you've got an A3 printer and want to do full prints then no as the paper size can be up to 13" x 19" if your A3 printer will take A3+ paper.
  3. #3
    Member NikGrey's Avatar
    Join Date
    Sep 2013
    Location
    Norwich
    Posts
    910
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You will be wanting to see the Auto Clam Range from xPress - Stahls is the USA equivalent to Adkins in the UK (Xpress re-badge Adkins with xPress) unless I am mistaken.
    I am about to buy the Auto Clam Junior from xPress - in the next few days.
    The Junior is 400mm x 400mm or the Senior is 400x500.
    Depends again on the space you have - if I had the space I would have a Swing Press (By Adkins) but as I have limited space I am going for the Clam Press (And it looks Cool).
    I am a Noob though, just sharing what I am about to invest in.
    My website is open:
Posting Permissions
  • You may not post replies
  • You may not edit your posts
