User Tag List
Similar Threads
  1. 11oz mug templete.
    By twinx05 in forum Mug Presses & Ovens
    Last Post: 02-05-2014, 06:50 PM
  2. Help using iphone template, also cut template from image
    By rob88 in forum Graphics & Artwork
    Last Post: 29-09-2013, 11:15 PM
  3. For Sale 11oz Mug Press
    By lemontdetroit84 in forum Buy It, Sell it, Give it away!
    Last Post: 03-03-2013, 01:33 AM
  4. 11oz Sublimation mugs
    By ALAN G in forum Mug Presses & Ovens
    Last Post: 28-10-2011, 01:12 PM
  5. 11oz mugs
    By Paul in forum General Dye-Sub Chit Chat
    Last Post: 25-10-2010, 12:02 PM
Results 1 to 2 of 2
  1. #1
    Senior Member
    Join Date
    May 2010
    Location
    Sunderland
    Posts
    1,005
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    11oz mug template
    Hi
    I'm after a plain mug template for a 110z mug in PSD file format
    Matthew
  2. #2
    Senior Member bms's Avatar
    Join Date
    Oct 2009
    Location
    Dorset
    Posts
    4,079
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: 11oz mug template
    All you need to do is create a new file, measuring 95mm tall (if that is the height of your mug) x whatever width your mug press will do. To check the width, place a piece of string around the mug from where you can get a decent print by the handle and wrap it round the other side, then measure the string. If you want a width larger than 200mm then you'll need to print in landscape on the paper.
    All you need to do is create a new file, custom settings at, say 95mm x 220mm x 300dpi and you have your template. Once you've done your artwork then flatten the image, create a new document, say A4 in landscape (297mm x 210mm x 300dpi) and drag the finished artwork into the new document, position it so you can get another printed on the same document and you can then print 2 up on 1 A4 sheet.
    Alternatively have a look at Paul's website for templates.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
