Although, if you are using daylight as the main light source the colour temperature of that light will change throughout the day and year.
Ok,
Had time to get into this a bit deeper - I have been amongst the camera's menu much deeper.
The Colour temp of the lamps is 5500k so I found this temp adjustment and set it to that and had a test, it was a bit Pink - went gradually down to 4600k and it started to get Blue but was not happy with anything.
So, Tried Auto White Balance which looked great.
In the end I found that 'Daylight' seems to be the best setting - I can even adjust the daylight balance but left it in the middle, had to use Macro and change the EV a bit and we now have this:
My website is open:
A few clicks in Photoshop...
...Gives a pure white background
I didn't edit the size of the image, so not sure why it's gone so small :-(
